SHARE YOUR FENCE SRETCHING TECHNIQUES
   / SHARE YOUR FENCE SRETCHING TECHNIQUES #1
JHFV
ENNIS TEXAS
mahindra 3525
Im restretching and putting up a bunch of new fence on my land. Its all field fence the kind with squares in it. Ive been nailing it to a 2x4 and pulling in it with the comealong, but it doesnt want to pull everything at the same time. I was wondering how you guys do it? Any tips I would appreciate! thanks
   / SHARE YOUR FENCE SRETCHING TECHNIQUES #2
For mine I took 2 2x4's and screwed them together with the end of the fence clamped between them. I put eye bolts on the top and bottom of the 2x4s and pulled with a come along.
   / SHARE YOUR FENCE SRETCHING TECHNIQUES #3
I did mine the same way Shawn did his. Where possible, I hooked the come-a-long to the tractor and used the tractor to tighten it a little and then did the final tightening by cranking the come-a-long handle. It worked great.
   / SHARE YOUR FENCE SRETCHING TECHNIQUES #4
I'm with Steve pretty much to the letter. Help a guy build fence just like that.. two, 2X's screwed together and pull with the tractor. Was a VERY nice fence when we were done.:D :D
   / SHARE YOUR FENCE SRETCHING TECHNIQUES #5
I built one of those stretchers with three hooks welded on a pc of pipe with a ring to hook the come-a-long to webed a pc of rebar through the fenceing and hooked the Hooks (loops) to and it worked well. jb
   / SHARE YOUR FENCE SRETCHING TECHNIQUES #6
I also use the 2x4s fastened together with eye bolts with the wire fence in between.
On the other hand, I don't hook it to the tractor, because its not heavy enough. When I'm cranking it tight, the tractor moves too. That does make it harder to tighten because I have to use some other post as the anchor, and there is not always one available. If it is on a straight section, there is no problem as I mount the fence to the one end (post) and tighten the other end of the wire fence(in the middle of the line of fence posts). Otherwise if I am at the other end (short fence) or going around a corner, I might not have a good anchor.
I tried using my wife's Silverado once, parked sideways, and it still moved the truck. And she doesn't like her baby out in the field.
Pete
   / SHARE YOUR FENCE SRETCHING TECHNIQUES #7
I have a rig like JohnD's. Works great with a chain looped thru it and hooked to the bucket.
   / SHARE YOUR FENCE SRETCHING TECHNIQUES #8
I used two pieces of 1 X 2 rectangular tubing bolted together. I put a chain on each end and hook to the bucket hook. I ease the tractor back till it justs starts to get tight then curl the bucket back till it feels right.
   / SHARE YOUR FENCE SRETCHING TECHNIQUES #9
A guy loaned this stretcher to my brother. The design looked so good I took some pics and may make one.
   / SHARE YOUR FENCE SRETCHING TECHNIQUES #10
I also use 2X4's with several bolts thru them. Then I wrap one end of a short chain near the top and the other end near the bottom. Then hook the come-a-long to the center of the chain.
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50323)
2016 Big Tex 14LX...
2021 John Deere 5045E  Only 86 Hours, Loader Ready, 2WD, Canopy (A52748)
2021 John Deere...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A50323)
2009 Peterbilt 384...
McDon 75D Flex Draper Head (A52349)
McDon 75D Flex...
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
2015 Ford Fusion Sedan (A50324)
2015 Ford Fusion...
