Dftodd
Super Star Member
- Joined
- Oct 19, 2014
- Messages
- 10,463
- Location
- vilonia, arkansas
- Tractor
- Massey Ferguson 1825E, Kubota Z121S
I've posted this a couple times on here.I've seem Fords doing the same thing as well.
Ford has a frame rail support kit that needs to be added if your gonna use the truck under certain applications.
The issue his lots weight past the rear bumper.
The weight of the engine is so heavy, when weight is placed behind the rear bumper, it causes the frame to crack right behind the cab.
I have three trucks at work that had to go through the recall and have the rails installed.
Two of the trucks, it was a pretty big ordeal since the utility bed needed to be removed.
Both trucks had hydraulic controlled air compressor generator combos, and my service had the added issue of having a crane.
The flat bed wasn't a big deal. Ford un-bolted the bed, lifted it and did the repairs.
The service trucks had to go to a third party outfitter to have the beds removed and reinstalled.
Those bed campers as well as certain towing applications would fall under needing the frame rail supports installed.
