   / Share Pics of People Hauling or Towing Something Wrong #21,531
I think this may be way you see so many Jeeps towed behind RV's, as they're smaller and lighter than pickup trucks and Suburban's...
And here I thought those (late model) Jeeps being towed were all about the image of being outdoorsy.
After all, Jeeps modified to be usable on real trails generally don't lend themselves to being flat towed.
   / Share Pics of People Hauling or Towing Something Wrong #21,532
General question, tandem trailering and trash bag windows aside: Trailers over 3000 lb. require brakes in PA, and I suspect most states have similar limits. So how are these types of car haulers ever legal?
It appears most states require brakes on only one axle of the trailer, such that the towing dolly could be outfitted with brakes to make it legal. But in some states, including Pennsylvania, brakes are required on all axles of any trailer over 3000 lb. That doesn't seem possible with this type of rig.
Most Uhaul trailers have surge brakes. Do the dolly’s have surge brakes as well?
   / Share Pics of People Hauling or Towing Something Wrong #21,533
Yes, car haulers as well as dollies.
   / Share Pics of People Hauling or Towing Something Wrong #21,534
   / Share Pics of People Hauling or Towing Something Wrong #21,535
While it may look odd they probably are OK. Everything is held solidly in place, if you look closely you will see straps on all of the smallest pipes as well as over the load.
   / Share Pics of People Hauling or Towing Something Wrong #21,536
It’s obvious not solidly held in place or it wouldn’t be falling off. The DOT requires more than 2 straps for a load 20 ft long and with the pipe falling off now he’s over sized
   / Share Pics of People Hauling or Towing Something Wrong #21,537
There is a chain holding the pipe in place; also a strap over the pile, as well as another holding the smallest . It likely isn't kosher, yet more solid than you might think. It likely moved after he left the loading site and did what he had to to keep going.
   / Share Pics of People Hauling or Towing Something Wrong #21,539
With that angle it won't be long before the smaller pipes nested inside that one that fell will slide out. They are not secured.
They are secured, there is a strap across the smallest pipe which holds the rest of them in.
It doesn't really show unless you zoom in on the picture.
However 4570Man spoke with the knowledge of DOT laws, while I was just giving my opinion based on what I see in the photo.
   / Share Pics of People Hauling or Towing Something Wrong #21,540
Well it sure is overwidth now... 🤣
2025 Ligchine Spiderscreed Concrete Screed (A56857)
2025 Ligchine...
Rotary SPOA9-200 Automotive Lift (A56857)
Rotary SPOA9-200...
2014 GR TRAILER 20' T/A UTILITY TRAILER (A58216)
2014 GR TRAILER...
2006 Dodge Ram 1500 Pickup Truck (A56858)
2006 Dodge Ram...
SDLL60 Loader (A55272)
2016 Club Car Carryall 1500 4x4 Utility Cart (A55758)
2016 Club Car...
