   / Share Pics of People Hauling or Towing Something Wrong #18,981
I hope you're exaggerating. I have rewired three trailers in the last 14 years, and all three are still working exactly as they had on day one.
For full disclosure, I did replace one tail light assembly on one of the boat trailers after several years and several hundred launches. A few of the 20-odd LED's in that assembly stopped working after enough dunks in the lake and bay, but the wiring is rock-solid.
no I am not ... and the last time I made sure all the wires was well secure in split tube, taped it up and put in cables clamps and tuck everything out of the way and the first ride it got knock out...
   / Share Pics of People Hauling or Towing Something Wrong #18,982
Wow... dunno what to say about that! My landscape trailer has all wiring inside the frame, totally protected, as does my smaller boat trailer (1960's Elgin). My larger boat trailer (1980's Wesco) has exposed wiring, hung inside the C-channel frame with those hammer-on metal clips, but it's held fine since I did it ca.2008.
What do you think went wrong with yours? Usually, the only trouble I ever see with trailer wiring is corrosion at the connection points, on trailers left outdoors, or UV breakdown of the wiring insulation if they're left in the sun. Both of those failures take years, not days!
   / Share Pics of People Hauling or Towing Something Wrong #18,983
Geez, is there anyone you cannot try to troll?
šŸ˜
   / Share Pics of People Hauling or Towing Something Wrong #18,984
Rocks hit it and the way the lights are I would've had to drill holes through the frame to get to the lights in order for the wires to be totally protected. But I didn't do it so I had to go around the frame exposing the wires.
   / Share Pics of People Hauling or Towing Something Wrong #18,986
If you have open C-channel, then these clips are about the best thing I've found for hanging wiring in a semi-protected way. Never as good as full tube frame, but better than having it above or below the frame rail, as you can "hang" the wire from these clips inside the half-protected c-channel:
Rocks are something I hadn't really thought of, if you're towing on a gravel or dirt road. All of my high speed or long distance towing is on asphalt, really only the landscape trailer ever goes off road, and even then it's low speed thru a field to pick up logs.
   / Share Pics of People Hauling or Towing Something Wrong #18,987
Another wire protection option for open frame trailers is to secure electrical tubing aka EMT to the frame for the long runs.
   / Share Pics of People Hauling or Towing Something Wrong #18,988
I've seen some old trailers with metal conduit welded in to the open side of a c-channel frame, or under a railing on landscape trailers. Probably not EMT, which is usually zinc plated and will flake most paint, but some plain steel tube.
   / Share Pics of People Hauling or Towing Something Wrong #18,989
I find it hard to believe any state would not require trailer lights all the time, day or night, no matter if you can see the truck lights or not.
   / Share Pics of People Hauling or Towing Something Wrong #18,990
I haven’t looked up any state laws but the vast majority of wood splitters don’t have taillights. I doubt virtually every manufacturer would sell something that clearly breaks the law if they were required.
2013 John Deere 245G LC (A55272)
2013 John Deere...
2016 Husqvarna YTA22V46 46in Riding Mower (A56859)
2016 Husqvarna...
Utility Trailer (A56859)
Utility Trailer...
2012 INTERNATIONAL PROSTAR+ (A58214)
2012 INTERNATIONAL...
2022 Polaris Ranger Utility Cart (A55787)
2022 Polaris...
WACKER NEUSON LIGHT TOWER (A58216)
WACKER NEUSON...
