   / Share Pics of People Hauling or Towing Something Wrong #16,741
Looks like part of what makes that crossing so dangerous is that it isn't at right angles. You would need to twist your head around extremely, to look for a train coming that is moving nearly parallel to you.
   / Share Pics of People Hauling or Towing Something Wrong #16,742
My son said Amtrak runs 90 MPH through there.
   / Share Pics of People Hauling or Towing Something Wrong #16,743
   / Share Pics of People Hauling or Towing Something Wrong #16,744
My son sent this to me. I don’t know who he got it from.
   / Share Pics of People Hauling or Towing Something Wrong #16,745
Is that the Amtrak crash situation? Do those passenger cars really weigh enough to require a truck with that many axles? They're basically just a big empty can with seats.
   / Share Pics of People Hauling or Towing Something Wrong #16,746
That is the scene. I assume it’s similar to this
   / Share Pics of People Hauling or Towing Something Wrong #16,747
Interesting. Surprising weight.
   / Share Pics of People Hauling or Towing Something Wrong #16,748
A difference between passenger rail in the US and high speed rail elsewhere, is US passenger railcars have to meed a high standard for surviving a crash with a freight train. This was enacted because they run on the same tracks, and probably after some horrific crashes.
I think our urban 'Light Rail' can be much lighter because of dedicated routes.
   / Share Pics of People Hauling or Towing Something Wrong #16,749
Near my hometown a train hit a tracked manlift that was used to trim trees. Because the lowboy couldnt pass this overpass without getting the bed stuck on the rails, they waited for the train to pass, so there was time to pass the single rail at snail pass, before the next train, because the max speed of this tracked manlift was only 1 kmh
Unfortunately there is a double rail section further down the rail so trains can pass, so a train came in opposed direction before the railway was cleared.
While in previous years the national railways ran a "ape head" train, model year 1964 on this line, with a welded front of sheet metal on structural section ribs, this line was spun off to the private sector, and operated by a company that bought a flimsy train with a glassfiber front. It derailed when hitting the 12 ton manlift, killing the engineer in the process. It was a matter of pure luck that the train was allmost empty at that time.
Here a video of the Dutch NTSB:
When in another village 25 years ago a 15 ton Cat 212B wheeled excavator was hit, the firemen had to cut the engineer from the train because he was slightly pinched, but he lived and fully recovered. The excavator operator however, was dug out from his cab so he could climb out on his own. Needless to say, the Werkspoor train didnt derail, it just had to be towed because the control room was damaged.
Here an image of a Werkspoor "ape head" under construction:
   / Share Pics of People Hauling or Towing Something Wrong #16,750
I wish I had pictures from 1986? 1987? Thereabouts when I voluteered to help a friend do a roof repair at his girlfriend’s family’s bungalow out on Long Island.
roof repair became roof replacement.
On the roof of my 1975 Chevy Impala: 18 sheets of plywood.
in the back seat: 20 rolls of asphalt roofing.
in the trunk: 10 more rolls of roofing and 5 buckets of tar, and several boxes of nails.
on the radio in a perfect world would have been War “Low Rider”…
2012 FREIGHTLINER CASCADIA (A58214)
2012 FREIGHTLINER...
2007 KALMAR 30 YARD SPOTTER (A58214)
2007 KALMAR 30...
2013 Sakai SV510 Pad Roller, Chassis# VSV21-1033, PMC Power Motive, Cummins Turbo Diesel Engine, (A59076)
2013 Sakai SV510...
2021 CATERPILLAR TL943D TELESCOPIC FORKLIFT (A52705)
2021 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2256 (A58376)
2256 (A58376)
