   / Share Pics of People Hauling or Towing Something Wrong #15,302
Was in Vegas recently, and saw yet something else I've never before seen.
This pickup had "outriggers" on both sides-- hauling rebar on both sides. Trust me, if you were near that, you would not want to be. And bicyclist and pedestrians better watch out!
   / Share Pics of People Hauling or Towing Something Wrong #15,303
Just a bit unsecured load there! Maybe over width also!
   / Share Pics of People Hauling or Towing Something Wrong #15,304
I've seen similar but under the truck.
At least the vehicle isn't any wider...
   / Share Pics of People Hauling or Towing Something Wrong #15,305
That would be absolutely illegal over here and should be everywhere. Bloody dangerous.
   / Share Pics of People Hauling or Towing Something Wrong #15,306
every glass and granite company has outriggers on their pickups and van's like that . the problem is that there is no middle support and rebar is not tied down properly. max width is 102 " around here . Definitly under that . 🍻
   / Share Pics of People Hauling or Towing Something Wrong #15,307
If you look close there is a middle support but it is lower than the front and rear. That allows the doors to open. Not secured except for gravity.
   / Share Pics of People Hauling or Towing Something Wrong #15,309
I agree 102 is the federal law and it is under that. But the 3 required ICC lights front and rear are not there. So being over 80 inches it's not legal without them even empty.
But technically every pickup that doesn't have cab lights towing a trailer over 80 inches is not legal unless the trailer is tall enough and has them on the front.
25 DUAL AXLE GOOSENECK TRAILER (A55745)
25 DUAL AXLE...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58018)
2019 FREIGHTLINER...
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
2006 Tusk 500 PG-16 Forklift  3-Stage 188in Lift with Aux Hydraulics (A56435)
2006 Tusk 500...
Voltage Converter, Single Phase, 240 Volt Input, 120 Volt Output (A59076)
Voltage Converter...
2012 Ram 3500 Crew Cab Flat Bed Truck (A56858)
2012 Ram 3500 Crew...
