   / Share Pics of People Hauling or Towing Something Wrong #9,231
This is a full galvanized trailer. I don't really want to messed that up by welding or drilling holes.
This is also a multi-purpose trailer. I will build the sides for it eventually so I can haul sand, gravel and whatever it may haul. The sides will probably cover the side rails.
   / Share Pics of People Hauling or Towing Something Wrong #9,232
Looks like you have pull up tiedown anchors every few feet on the sides, perhaps use those (would need different straps)? If not, something like this: https://www.amazon.com/Forged-D-Rings-Trailer-Tie-down-Ring-27014/dp/B013QE9TZ8 might match the existing holes or bolts.
Aaron Z
   / Share Pics of People Hauling or Towing Something Wrong #9,233
I have said it before and it bugs me. DOT insists on strap integrity but disregards what it is attached to. I have a commercially built dump trailer (DJD) and it looks like a four year old with a stick welder put it together.
   / Share Pics of People Hauling or Towing Something Wrong #9,234
Aaron Z
The ones that came with the trailer look a bit to weak to hold a 4000 lbs tractor. They are rated for 1100 lbs and are just a bit over 3/8" (10 mm) in diamater.
I might give those D-rings a try once I source them over here in Portugal.
   / Share Pics of People Hauling or Towing Something Wrong #9,235
I also find that pretty humorous. I also believe in most cases a properly installed hook point would rip off before a 3/8 chain breaks. Another thing I see that bugs me is D rings welded on wrong. They’re only rated for a straight pull and weight rating is only a small fraction of the original working load pulling on them sideways.
   / Share Pics of People Hauling or Towing Something Wrong #9,236
Or use some wood screws and mount that recessed D ring to the wooden deck!
   / Share Pics of People Hauling or Towing Something Wrong #9,237
Why did you buy it ?
   / Share Pics of People Hauling or Towing Something Wrong #9,238
The lane's not so much the issue as following a car length back from group of cars at 75mph for 30 miles.
SO TRUE !!!!
   / Share Pics of People Hauling or Towing Something Wrong #9,240
Some suitcase weights would do that tractor wonders.
JCB Forks and Frame Skid Steer Attachment (A56857)
JCB Forks and...
1611 (A57192)
1611 (A57192)
Mahindra 6065PST (A53317)
Mahindra 6065PST...
New/Unused IRGC40 Mini Golf Cart (A57453)
New/Unused IRGC40...
PALLET OF JACKS AND JACK STANDS (A58214)
PALLET OF JACKS...
NEW Wolverine 72in Skid Steer Tiller (A59000)
NEW Wolverine 72in...
