   / Share Pics of People Hauling or Towing Something Wrong #3,601
Someone mentioned tires hanging off the side, this one has nothing under the tires, body is blocked up from the lowboy.
A lot of heavy equipment is moved like this. There are trailers called "beam trailers" that are like a regular lowboy but don't have the side areas where the tires might sit. Only the center beam, as wide as the portion between the rear wheels.
   / Share Pics of People Hauling or Towing Something Wrong #3,602
Agrd.. that's -very- normal, and legal, here.
   / Share Pics of People Hauling or Towing Something Wrong #3,603
Reminds me.
In high school we fixed up a 70's model ford pickup for a teacher. He had no budget for replacement parts but dropped bondo off by the gallon. Had 2 1/2 gallons in the drivers door and a gallon above each rear wheel. Seems like another gallon spread out else where. Then painted candy apple red.
I try to minimize the use of Bondo whenever possible. It's just rarely possible. :D
TBS
   / Share Pics of People Hauling or Towing Something Wrong #3,604
" A gallon of Bondo is cheaper than a new quarter panel".
Or duct tape. ~25 years ago I had a VW rabbit with much rust. Every year at inspection time would replace the rotted off back hatch edge and cover the rocker panels with duct tape then spray paint to match. Then abused it for another year.
   / Share Pics of People Hauling or Towing Something Wrong #3,605
:thumbsup:
   / Share Pics of People Hauling or Towing Something Wrong #3,606
Howling, where did you get your duct tape? From roads and bridges dept? image.jpg
   / Share Pics of People Hauling or Towing Something Wrong #3,607
Went to the local building supply house. When I pull in they are crawling under a truck. Ok no big deal. Until I realize they are tying 2x8's under it. I'm guessing they bought 20'ers. Only had a 6 ft bed truck. Wife says "Look at my idiot husband. " I just smiled and said whatever works. ImageUploadedByTractorByNet1464828901.004277.jpgImageUploadedByTractorByNet1464828938.354486.jpg
   / Share Pics of People Hauling or Towing Something Wrong #3,608
Went to the local building supply house. When I pull in they are crawling under a truck. Ok no big deal. Until I realize they are tying 2x8's under it. I'm guessing they bought 20'ers. Only had a 6 ft bed truck. Wife says "Look at my idiot husband. " I just smiled and said whatever works. View attachment 470512View attachment 470513
Yep, a city boy truck.
   / Share Pics of People Hauling or Towing Something Wrong #3,609
   / Share Pics of People Hauling or Towing Something Wrong #3,610
Must not have an opening back window.
I have heard of people doing that with steel or pipe...
MARATHON 25KW GENERATOR (A58214)
MARATHON 25KW...
SKID STEER ATTACHMENT AUGER (A58216)
SKID STEER...
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
1997 Peterbilt 378 Tri-Axle Heavy Haul Truck, VIN # 1XPFD69X4VN428289 (A57453)
1997 Peterbilt 378...
Mini-Excavator Forks (New/Unused) (A59225)
Mini-Excavator...
