   / Share Pics of People Hauling or Towing Something Wrong #5,891
It would make make more sense if we hadn't lost some of the intermediate measurements.
Jack.......2.5 fl oz
Gill........5 fl oz
Cup.......10 fl oz
Pint.......20 fl oz
Quart....40 fl oz
Pottle....80 fl. oz
Gallon...160 fl oz
Bruce
Imperial measurements I assume ? Just in case i ever haul something in yesteryear Britain :)
   / Share Pics of People Hauling or Towing Something Wrong #5,892
Metric has been legal for decades... just not mandatory.
When I was doing construction in Europe... the residential water pipe and fittings were still called out 1/2 and 3/4... go figure?
   / Share Pics of People Hauling or Towing Something Wrong #5,893
Carpentry in feet and inches is needlessly complex. Try to calculate the distance from the end of a roof to the edge of the first of three dormers equally spaced, in a roof where the dormers and the roof itself measure some odd numbered feet/inches/fractions of an inch. (Without a pocket calculator that does fractions, obviously).
Or work out the rise/run measurements for stairs. Be sure to allow for carpet on the stairs but not on the floor of the lower level! Dividing vertical height by number of stairs is sure to result in some weird, hard to calculate fractions for each rise.
Concrete calculations considering area, depth, volume then ordering material in cubic yards takes some figuring. Base 27 mathematics???
(Once upon a time Journeyman Carpenter here, obviously pre pocket calculators).
Conversion to Metric will be gradual, particularly because building materials are in inches, but construction calculations will be simpler after we follow the rest of the world into the modern era.
   / Share Pics of People Hauling or Towing Something Wrong #5,894
I wonder if that anomaly has anything to do with the fact that 1/2 and 3/4 aren't really the measurements of the pipe, just a name, like "2X4" for instance? Or "half ton truck". And the dimensions are different if it's copper or iron, but the names are the same. Of course, unless you're talking about "tubing" instead of "pipe". Then it's the actual OD vs the imaginary approximate ID with pipe. But then we have 1/2" PEX, that is called tubing, but measures 5/8" OD. So is it tubing or pipe? 3/4" copper pipe is the same thing as 7/8" tubing and definitely not 3/4" anywhere. Sheesh.
   / Share Pics of People Hauling or Towing Something Wrong #5,895
There are weird numbers "in metric" too. Being base 10 doesn't make everything magically work out.
   / Share Pics of People Hauling or Towing Something Wrong #5,896
1/2 & 3/4 refer to the ID (In inches) of the water pipes installed in UK buildings. Changing the piping is impractical and there is a lot of water piping in existence - since before the Mayflower sailed westwards. Likewwise the Mile-Marker posts on the roadside for the stage-coaches pre-Shakespeare.
Because we were colonised by the British, as you were, our pipes are similarly "called" 1/2 & 3/4, even 1 inch etc. But new building & construction is dimensioned in metric terms.
1/2 and 3/4 inch ID piping should really now be called 13 & 19mm. (Which it is on mainland Europe).
The post by 'California' on this page and 'Raspy' on P.589 are excellent contributions to this debate. :thumbsup:
   / Share Pics of People Hauling or Towing Something Wrong #5,898
The rise/run/accounting for carpet was one just mentioned.
Equally spaced anything could end up with .38474759483625 or whatever.
As a (mechanical) engineer, I assure you, even numbers rarely just happen. If you want it, then other things around it will be "non-even".
My dad owned a machine shop. Hundreds of thousands of dollars in (what my college roommate affectionately called) barbaric units. Those machinists would have to convert forever, introducing error.
Converting is painful. It was always easier 50 years ago.
   / Share Pics of People Hauling or Towing Something Wrong #5,899
Yes but you can find .38474759483625 directly on your ruler. Faster, more accurate, more intuititive than looking for 25/64ths. Or converting that to 1/8ths plus a smidgen, or something else you recognize instantly.
   / Share Pics of People Hauling or Towing Something Wrong #5,900
Agreed.
Good job copying my made up decimal number.
2016 DRAGON SAND CONVEYOR (A58214)
2016 DRAGON SAND...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
1998 PETERBILT 379 DAYCAB (A58214)
1998 PETERBILT 379...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A59575)
2018 FREIGHTLINER...
SHOPMADE MANIFOLD TRAILER (A58214)
SHOPMADE MANIFOLD...
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52709)
(INOP) 2019 KUBOTA...
