   / Share Pics of People Hauling or Towing Something Wrong #18,551
What are those 3 legged ladders used for?
I've always seen them used by landscapers and horticulturalists. Your mention of orchards makes sense too, although I've never seen them spiked into the ground. I think they're just for any place not level enough for a regular 4-legger.
   / Share Pics of People Hauling or Towing Something Wrong #18,552
Grew up on a fruit farm using that type ladder in the orchards.
Learned not to use them on a cement surface the hard way.
Why would I go get a 4 legged ladder to change some light bulbs in the barn?
These were right there.
That middle leg swings out as far as you need to set up around trees. It digs into the grass/soil and is very stable.
Not so on cement, as I painfully discovered.
The middle leg has nothing but friction to stop it sliding out to 180 degrees.
Concrete doesn't have much friction.
I was on top of an 10 foot ladder, fully stretched out to reach the bulb, when i was face first on the cement.
The middle leg slid out so fast I didn't even have Willie Coyotes moment of, "OH CRAP"
Surrounded by broken glass and in some serious pain I slowly got up. I was sore for weeks.
I use the right ladder now.
   / Share Pics of People Hauling or Towing Something Wrong #18,553
...I use the right ladder now.
Yeah. I have a couple of wood 4 leg ladders for building maintenance. That seems a lot safer for anything near electricity as well as avoiding that inevitable leg-slip.
Tallman seems to be the best orchard ladder now. Lightest weight and a much better attachment of the pole at the top. Durable. My neighbor who harvests here just piles a dozen of them randomly on his flatbed, straps them down, and I've never seen one dented.
I bought an 8 ft Tallman for wife. Then 11 ft for me, the heaviest that I want to carry hundreds of ft on rough sloping ground. These are ideal.
Here's a photo from 2007 just before I bought the Tallmans. I got the ancient 14 ft wood orchard ladder from a cherry farmer who was retiring. Its too flimsy, shaky, to use anywhere that you can't steady it against a limb, high up. The one on the right is a 10 ft aluminum Stokes, notably heavier than the 11 ft Tallman.
And for Subaru admirers, my 'farm truck'. 1999. At 24 years it still looks as nice as this old photo. A clean California original with no rust at all. (The Hauling part of this post. :) )
p1040280rladders-14-10ft-jpg.81975
   / Share Pics of People Hauling or Towing Something Wrong #18,554
Do these 3-legged ladders not have anything to limit how far out the third leg can go? Seems like a strap could be used for this and still allow it to be used over shrubbery or smaller trees.
   / Share Pics of People Hauling or Towing Something Wrong #18,555
The decal inside one leg, says a strap is mandatory for firm ground or a hard surface. But I've never seen a strap used.
An urban landscape contractor might have straps on everything.
It's normal to jump on each side of the first step before mounting. Then after climbing a couple of steps, buck back/forward to sink the front leg and make it secure. In my apple orchard at least one of the three legs will usually sink in a few inches due to gopher runs that weren't apparent.
A major advantage of the 3 leg ladder is its ideal for sloping ground. (everything here). On a steep slope, the front leg can be set way out front to get to where each stair is level. Also for a slight side slope, the front leg can be offset from straight ahead to center your weight above the weight-bearing points.
In summary, a specialty tool that is excellent for orchard use.
   / Share Pics of People Hauling or Towing Something Wrong #18,556
That probably depends on the brand. On mine the hinge at the top limits the opening. Mine are aluminum and I never use them on hard surfaces.
   / Share Pics of People Hauling or Towing Something Wrong #18,557
Interesting. No limit on mine. it's not unusual to lift the front leg high and put it through a crotch in a dense apple tree then plant it on the far side, to get in close and harvest the center of the tree.
   / Share Pics of People Hauling or Towing Something Wrong #18,558
We have a 12' Stokes with the telescoping 3rd leg and hard surface kit options.
Picked it up from the factory when we lived in Lake County. Best ladders ever.
Patrick
   / Share Pics of People Hauling or Towing Something Wrong #18,559
Back in my ancient days of say 1979 on a Sperry Univac our Fortran card stack started with a job control card which stated limits on how many $ of CPU time and pages of paper this task was allocated.
Back in my school days, they were still teaching us how to hard-wire those old IBM Accounting machines. They had vertical type bars with alpha, numeric and symbol segments which were hit with hammers. It was actually fun to watch all those bars going up and down independently as it printed one line at a time. As I recall, it took about 5 minutes to print a page of green bar. They had memory listed in characters--Typically, 1400 so you couldn't add up very many columns. They were as noisy as a metal shredder.
   / Share Pics of People Hauling or Towing Something Wrong #18,560
By late 1991 made the mistake of demonstrating competence at Unix, in the midst of my employer’s DoD contracts getting re-written by the government (apparently they can do that) and I was transfered from an engineering development and analysis position to a well funded contract as a security officer and system administrator. Had $4M of state of the art SGI machines. 12 machines, 9 with the GT graphics hardware.
We had a couple Linetronix dot matrix green bar printers. These printers had dot matrix print head the full width of the paper. Not sure how many pins but not enough to cover the page, the print head was on a shuffle back and forth a quarter or half inch. The fastest printer could push the paper out the top so fast it would shoot up out of the top if the cover was not in place. And deafening loud if the cover open.
Got back to embedded design in 1993. Software and hardware.
Was also an Apple ][ guy, then Mac, and FreeBSD on PC hardware, and ever so thankful Apple MacOS X was Mach/FreeBSD based in 2000.
John Deere 7410 (A53317)
John Deere 7410...
John Deere 3025E (A53317)
John Deere 3025E...
2015 SKY TRAK 6036 TELEHANDLER (A58018)
2015 SKY TRAK 6036...
Kimball Midwest Wire Cabinet w/Wire (A59076)
Kimball Midwest...
2019 John Deere 310L EP Backhoe (A53485)
2019 John Deere...
5PC. WICKER SET (A58374)
5PC. WICKER SET...
