   / Share Pics of People Hauling or Towing Something Wrong #15,501
Lots of companies are going automatic (not automated), mine has been for about 6 yrs.
The government here still insists on manuals and I agree, but yeah, it's nice not having to put your coffee down to run through gears leaving a light. Other than that, I would prefer a manual. Even in the city.
Ours were automated, but had a fluid coupler, you put your foot on the throttle and the computer did the clutching and shifting, it felt like a standard shift on a 10 speed transmission , but I didn't touch anything. This was in a dump truck and trailer so, it was usually only a few miles from pit to job site. The only caveat was you had to remember to lock the transmission in 1st or 2nd when doing a spread job or transmission would upshift and thin the spread out as you went.
   / Share Pics of People Hauling or Towing Something Wrong #15,502
... only caveat was you had to remember to lock the transmission in 1st or 2nd when doing a spread job or transmission would upshift and thin the spread out
That reminded me of a job that I watched, fascinated, as a little kid. Many truckloads of fill moved about a mile. The dump trucks did something I had never heard of: quick acceleration through first and second gear then a near stall hitting a too-high third gear, and again for fourth.
These were early Hydramatics and apparently had the same ratios as that transmission used in Oldsmobiles and Cadillacs.
Years later I owned a '50 Olds 88 and what I had heard suddenly made sense. The Olds was well suited to those gear ratios. And some trivia - the early Hydramatics had a lockup, direct drive, fourth until about 1953. 20mpg in a model that had been used for CHP cruisers! Per Popular Mechanics they were the quickest and fastest American car when introduced.
   / Share Pics of People Hauling or Towing Something Wrong #15,504
Blue Flame 6 with 2 speed automatic at roll out...
I use to tow the outboard with my 57 Ford with mileage maker 6 and auto... this was not a small car and many times carried 8 inside.... 20mpg was no problem...
   / Share Pics of People Hauling or Towing Something Wrong #15,505
We don't refer to automatic or automated. It's either manual or automatic, so I'm not sure which I drive (and frankly, don't care).
It will leave a light in 3rd, then 6th, 8th, 11th. Relies on the torque at lower RPM.
I hate the way it skips gears because if anyone is watching it looks like I don't know how to shift. :) Lurches etc.
In snow storms the engine brake will cut off, and RPMs drop to nothing so no deceleration braking like the manuals had. Un-nerving at times.
If you are trying to go through a small snow bank and the wheels spin it takes throttle control away from you. Literally.
Then you're stuck because the truck will stop.
But.... I don't have to put my coffee down to leave a light.
I was the last hold out to keep my manual trans tractor out of around 50 drivers at the time. Until I had no choice. They just took the truck away.
Gave me a brand new 2019 Volvo VNR. It's OK. Has a satellite radio subscription LOL.
   / Share Pics of People Hauling or Towing Something Wrong #15,506
Dude is also carrying wrong....
Choosing to showcase and display what could, and should, instead be a concealed handgun is the height of stupidity.
You lose the advantage of knowing you are armed while others do not. And you turn the gun into a magnet for trouble-- maybe the least problematic is someone trying to grab it from you. Stupid!
   / Share Pics of People Hauling or Towing Something Wrong #15,508
I used to do that. Some of them were alcohol infused and I always hoped that increased my mileage.
   / Share Pics of People Hauling or Towing Something Wrong #15,509
He also has all the computers and digital tools he needs to work on them. That's probably a bias. I just changed fluid in my F250 for the first time and was shocked when I dropped the pan how many wires and sensors were inside the dang transmission! More plastic than metal was visible.
I can rebuild an automatic if I had to but much easier to rebuild the G56 in my 06 Ram3500 though it’s unlikely it will ever need more than a bearing or synchro.
That said, rush hour stop and go traffic isn’t but fun. Automatics are for commuter / consumable vehicles that won’t be around forever. This especially applies to the newer models, almost none of which have a serviceable filter.
Just my opinion of course.
   / Share Pics of People Hauling or Towing Something Wrong #15,510
Have to disagree, there's a reason the manual versions of Cummins have limited their output lower then the autos. Also the majority of the medium duty trucks are auto and have been for a while now, I wouldn't consider those consumer or disposable. I owned a 650 with an auto and would say it was much nicer to operate then any of my manual trucks and I grew up only owning manual vehicles (except for my 72 Cutlass which I converted to manual).
Honestly I would rather rebuild an auto then some of the newer manuals.
(2) 255/70R22.5 TIRES (A58374)
(2) 255/70R22.5...
2016 GENIE Z80/60 TELESCOPIC BOOM LIFT (A52709)
2016 GENIE Z80/60...
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A58216)
2008 MOTIV...
2014 FORD F-250 UTILITY TRUCK (A58214)
2014 FORD F-250...
CHEVROLET C-30 CAB & CHASSIE (A52708)
CHEVROLET C-30 CAB...
2014 Aerway Aerator (A55973)
2014 Aerway...
