Shan Dong / Tashan Tractor
   / Shan Dong / Tashan Tractor #1
DDMattox
Does anyone Have any info on a Shan Dong Tractor Works Tractor ? The Model is a Tashan 25. I Recently Aquired one and need a few parts even thought the Tractor Runs okay
Thanks for any help
   / Shan Dong / Tashan Tractor #2
(from the web)
“…Shandong Worldbest Shantuo Co.,Ltd. is one of branch companies of Worldbest Kama Machinery Co.,Ltd.("Worldbest Kama"), located at Yanzhou, one of the nine ancient Zhous of China in vicinity to Qufu, Confucian's hometown. It is the largest base of medium size tractors in China with the annual output 25,000sets tractors which cover 60% of domestic market among same line tractors and export over 30 countries and regions.
As an important affiliated enterprise, Shandong Tractor Works-the key manufacturer of China agriculitural machinery industry, jointed to set up the Worldbest Kama. With advanced workman design, strong technology, complete working equipments and test measures and perfect quality control system, the TS brand(Taishan)series tractors and Feidong brand(FD)series diesel engines produced by Shandong Worldbest Shantuo Co.,Ltd. and Shandong Tractor Works are sold well in domestic and international markets by super quality and international markets by super quality and reasonable prices with high reputation. Now, the mass production capacity of loaders, forklifts, other engineering mahinery and implements have been established in the enterprise.
Model TS250 tractors and Model FD295 diesel engines all won the prize of National Super Quality Products. Taishan brand Model 120,180,200,280,300,400,450series tractors and Feidong brand Model 295,52100 series diesel engines are the main products of enterprise, which have the characteristics of compact structure, easy operating, easy maintenance, lower fuel consumption, parts interchangable and multipurpose using. With top quality products, perfect servise a visionary managment and cutting-edge efficiency, the enterprise is ready to meet the customers requests and lead the way in the modernization of China agricultural industry." “
Shandong Worldbest Shantuo Co.,Ltd…
“For different purposes,Taishan 25HP series tractors are divided into:TS25A(Normal type),TS25K(High speed type),TS25Y(Transport type),TS25KS(For paddy fields),TS25-1(2-Stage clutch),TS25-2(2-Stage clutch and Creeper),TS25-4(Narrow wheel tread),TS254(4-wheel drive),TS254-1(4-wheel drive,2-stage clutch) and TS254-2(4-wheel drive,2-stage clutch and creeper).Besides these,Differential,Combined meter,Roll Bar,Hydraulic assistant steering,Wide wheel tread can be chosen by the users. “
Main Technical Data of Taishan 25HP series Tractors
shantuo@tstractor.com
   / Shan Dong / Tashan Tractor #3
hi,
I may be placing an order for some of these. I'd sure like your honest opinion of the tractor from a users point of view, either privately or here.
Also, it may be that I can get some parts ordered along with mine, but it will likely be 60 to 90 days away. What parts are you looking for?
Have you also posted on CTOA? Maybe someone there who can help sooner.
The Tractor I have Runs Well The bigest complaint I have is that mine is a single Stage clutch which should be no problem for Bush Hogging With the addition of an over run cluych But there is No hole thru the PTO shaft to attach the clutch and its a real Pain to install the Hole while its attached to the tractor. The parts i need are Wear Items such as filters and a few gaskets. Are there any Dealers presently in the US? The Tractor seems to be a good Piece of equipment This one is a 98 Model.
Thanks,
David
   / Shan Dong / Tashan Tractor #5
I am a Kama dealer and can get your parts. You can purchase a quick connect overrunning clutch that doesn’t need a hole through the PTO shaft. Give me a call we can talk about it
Buck
   / Shan Dong / Tashan Tractor #6
I have a quick connect, like Buck is talking about. It works great, and you can take it off easily when you don't want to use it.
   / Shan Dong / Tashan Tractor #7
Does anyone know where I can but a water pump for a Taishan TS-254 tractor?
Rick
   / Shan Dong / Tashan Tractor #8
Rick
TaiShan is a baby KAMA. As such, any KAMA dealer should be able to help ya out
//greg//
   / Shan Dong / Tashan Tractor #10
Hi Rick
Was you able to get a water pump?
If so where at and the amount.
Thanks Bob
2015 Timpte Hopper Bottom (A50514)
2015 Timpte Hopper...
2000 INTERNATIONAL 4300 17FT ROLLBACK TRUCK (A51222)
2000 INTERNATIONAL...
BROCE BROOM RCT350 SWEEPER (A51242)
BROCE BROOM RCT350...
IH Farmall 706 Tractor (A50514)
IH Farmall 706...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
John Deere 922 Platform (A50514)
John Deere 922...
