Shallow sockets ??
/ Shallow sockets ?? #1
bigtiller
Super Member
central Iowa
John Deere 2720 John Deere 3039R John Deere Z545R
I was driving a 3/8 x 5" lag bolt 3" deep into a concrete floor to bolt a small sheet metal break down. An impact driver works good for this but every socket I have is too deep. I had to stick a nut in the socket to take up space so I could keep downward pressure on the lag bolt. Otherwise it would not screw in, it would begin to strip out.
Does anyone make shallow sockets for this circumstance? Do they have a special name?
/ Shallow sockets ?? #2
I have make sockets for uses like that by taking one to the grinder and shortening it as necessary.
/ Shallow sockets ?? #4
Alot of higher end deep sockets are broached in such a way that the hex is only about a half inch deep. I know snap on does.
:thumbsup: Ha, that's a good idea, why didn't I think of that. I have 2 buckets of old rusty, dull and worn out tools that I am saving for ballast or my estate auction.
/ Shallow sockets ?? #8
I had a set of craftsman I got last century that were made shallow.
Last century? Ugh. And I thought my set of craftsman shorties were cutting edge technology. Actually, I have both sets, i.e. deep sockets and 'standard' short ones.
/ Shallow sockets ?? #9
Id hate to ruin a perfectly good socket by grinding it down to size. A steel rod cut to size and struck into socket with paper should work. Once work is completed, the rod can be punched out if it does not come out easily. I think I would try this first.
/ Shallow sockets ?? #10
Sometimes cutting or bending tools is the only way. For this use I'd have just put a spacer in it like you did. Did you pre drill a hole?
/ Shallow sockets ?? #11
I just stick one or two nuts in with a piece of masking tape works perfect. Would not grind up a nice socket for this purpose.
Pre-drill? Yes, well kind of. I set the break in position, drilled a 1" deep hole with a 5/16 SDS bit. Then slid the break 6" out of the way, set the depth gauge on the rotary hammer and finished drilling the holes with the same 5/16 SDS bit.
/ Shallow sockets ?? #13
If you use concrete anchor studs. Drill all the way through the concrete slab. If you have to in the future, you can drive the stud into the dirt for a new stud or just to get a flush floor again.
I have never drilled all the way through for any anchor. This time it was simply a 3/8 lag bolt. Other times I use this type;
Bad Request
But most of the time I use this kind which requires a blow with a hammer to start the set of the anchor before tightening.
/ Shallow sockets ?? #15
Bad Request
Concrete wedge anchors are the exact anchor type to drill a through hole for. You can't pull them out. If you could the anchor has failed its job. Many times the anchor point was in a critical location. Changing the hole meant changing either a lot of holes or equipment. Punching the old anchor into the dirt solved a lot of issues. Even drilling a larger diameter hole for a bigger stud is facilitated by punching the anchor through.
/ Shallow sockets ?? #16
Worked in a factory. All our Hilti bits were 18 inches for this reason.
/ Shallow sockets ?? #17
My impact sockets are all deep sockets. So when required - I've always done exactly as bigtiller did. I think I've used one or two concrete anchor bolts in the 35+ years here.
What type of anchor are you talking about? A picture would be great, just to make sure we are talking about the same thing.
/ Shallow sockets ?? #19
The one you pictured in post #14 "How to install wedge anchors" If you can pull it out, the hole diameter was too large. Thus a through hole is the only way to use another anchor (say the threads get damaged )
Are you talking about the link to a picture of one style or the video of another style titled "How to install wedge anchors" ?
AUCTION STARTS HERE @ 9AM (A64277)
AUCTION STARTS...
Skid Steer Deluxe Hitch Plate (A65640)
Skid Steer Deluxe...
Troy-Bilt Pony Riding Mower (A65579)
Troy-Bilt Pony...
Deutz DX140 Tractor (A66285)
Deutz DX140...
2007 Chevy Suburban (A62679)
2007 Chevy...
KBH Tank Trailer (A63689)
KBH Tank Trailer...
