BHD
Veteran Member
Setting up small Grain bin
pre cast footers on truck (in the half drums). Took drum half's into ready mix company, to save on mileage, (they said they would fill them for $20 each,
setting the footers used flat iron to help set the footers in the correct locations, for the legs,
backed up to footers and bed lifted (note: the 2x4's are to help support the legs when the bin is being lifted, they were removed when upright,)
legs attached to bolts of footers
bin up right put a chain on the top of the bin, and pulled it up with a come-a-long, (also put a rope) on it so I could control it when over centered going up,
I still have a few finishing touches on the bin before being able to use it,
not bad for no help.
