Grading Setting Up a Rear Blade on 3pt *DELETED*
   / Setting Up a Rear Blade on 3pt *DELETED* #2
Re: Setting Up a Rear Blade on 3pt
If you stand behind your tractor, you should have an adjustable link for the right side lower link (hitch point for the implement). The adjustable link will be like a large turnbuckle.
That levels the implement (rear blade) side to side. You can use a level if you like, but I just use a calibrated eyeball.
You mentioned the threads on the adjustable link don't lock in....isn't there a jam nut on that link? There should be...
As far as side to side sway, lower the blade and tighten up your anti-sway links. You'll still get some side to side movement (say...½" or so), but that's about it.
Sorry, should have read the manual first prior to asking stupid question. So, in another brilliant moment, I figured I'd delete the post so as not to waste more reader's time. /forums/images/graemlins/crazy.gif Well, this whole thread could have gone better. /forums/images/graemlins/tongue.gif
Roy - thanks for the input. I've pulled out the manual and dialed in the linkages.
1999 International F-4900 T/A Cab and Chassis Truck (A56858)
1999 International...
2019 Haulotte Star 20 ACE 19ft Scissor Lift (A55973)
2019 Haulotte Star...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2022 Kubota Z422-54 Zero Turn Mower (A55315)
2022 Kubota...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
2019 Ford Explorer (A55788)
2019 Ford Explorer...
