Setting Trusses with my 2015 (check out the pics)
   / Setting Trusses with my 2015 (check out the pics) #1
SteveCornell
Weston, West Virginia
2017 Kubota L6060 HSTC
Me and a buddy were trying to set the trusses on my new 24' x 40' shop and they were "kicking our butt" the trusses are 7\12 scissor trusses and while not very heavy are very difficult for 2 people to handle..............so I think how can I use my Mahindra 2015HST to help complete this task /forums/images/graemlins/grin.gif ....... I then go into "McGyver mode" and put one of my forks on the bucket then slip a basement jack I had lying around over the fork, I run a heavy nylon lifting strap down the basement jack tube and run a bolt through it, then I bend a piece of rebar and attach it to the strap and I have a custom truss boom pole, it worked great and the 2 of us had the trusses up in no time.... check out the pics below...
Steve
Picture 1
Picture 2
Picture 3
Picture 4
Picture 5
   / Setting Trusses with my 2015 (check out the pics) #2
See honey I told you I would use the tractor if you let me buy it.
NICE JOB /forums/images/graemlins/wink.gif
   / Setting Trusses with my 2015 (check out the pics) #3
Good idea /forums/images/graemlins/wink.gif Nice shop too, and it looks like your ROPS will clear your door.
I bought the tractor in June about the time I started building our new house and I honestly beleive by the time I get done the tractor will have paid for itself with all the stone I've moved, ditches I've dug, landscaping, and little tasks like setting the rafters and today I set a 40' 10" x 4" wood beam on top of 9' high treated posts.
The tractor has sure been a lifesaver during the building process.
The ROPS will clear the door, the door will be 12' x 10'.
Here's a link to my website with pictures of the new home under construction.
   / Setting Trusses with my 2015 (check out the pics) #5
very nice!
   / Setting Trusses with my 2015 (check out the pics) #6
Steve, I do alot of Construction work on the side. I was wondering with your boom pole ( which is very creative ) how high can you reach? I am getting ready to build a machine shop for myself. In the past, I have always hired a crain to set my trusses. I really like your idea of what you have done. I have a 2615 with a ML106 FEL. Also, your Shop and Home looks very nice!
duckkiller,
I was lifting these trusses to 15', the pipe \ basement jack slipped over the clamp on fork is 8' long.
This put no strain at all on the bucket as the trusses were not that heavy, I was really supprised at how easy it lifted the trusses.
   / Setting Trusses with my 2015 (check out the pics) #8
Thanks for posting the pics Steve. Do you have a guess as to how much the trusses weighed?
I would "guess" the trusses weigh 175 - 200 lbs each
   / Setting Trusses with my 2015 (check out the pics) #10
That's a pretty long lever arm to work against the front bucket. I suspect a bigger load would be a problem, either with the bydraulics or balance, depending on how you use it. If you had some way to telescope the thing from a vertical position you could lift more with less risk. As it is, it worked great, but I bet OHSA would have fits with it. /forums/images/graemlins/laugh.gif
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
2006 MACK CT (Granite) (A50323)
2006 MACK CT...
UNUSED CFG Industrial MY50R Mini Excavator (A47384)
UNUSED CFG...
HYSTER S50FT STRAIGHT MAST FORKLIFT (A51242)
HYSTER S50FT...
2016 Toyota Prius Hatchback (A50324)
2016 Toyota Prius...
2024 AGT INDUSTRIAL QHT-500FL CONCRETE BUGGY (A51242)
2024 AGT...
