setting top link on 1735m and a Brush Hog
   / setting top link on 1735m and a Brush Hog #11
It all depends it you need to work in the ground or ontop of it .
In the ground you need the tractor to respond and that wil show you witch hole on the tractor.
Ontop of the ground it must not respond.
Length:
Stand at the side of the tractor and look at it and the impliment.
Draw an imaginary line by lenthening the lower links and the toplink to the tractor.. Those 2 lines must meet somewhere between the steeringwheel and the front of the hoode. The more forward the better traction you will get.
   / setting top link on 1735m and a Brush Hog #12
You all have forgot the back wheel height. I don't see the real wheel as a deck height set. That single wheel is too narrow to carrier weight without rutting. So I set front of deck to mow height, then set the top link to either level if you have discharge relief area or a tad higher than front for no discharge. Thus tension on the toplink, which is connected to a flexlink. Thus rear wheels main use is to keep you from scalping when tractors heads up hill or you back up a bank.
2007 Peterbilt 335 Mickey AO-A Battery Truck (A50323)
2007 Peterbilt 335...
E-Z Trail 675 Grain Cart (A50514)
E-Z Trail 675...
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
Loader Arm (A51691)
Loader Arm (A51691)
Fifth wheel multi use trailer. (A52128)
Fifth wheel multi...
2019 CATERPILLAR 316FL EXCAVATOR (A51242)
2019 CATERPILLAR...
