Setting posts atop existing concrete patio...anchor?
   / Setting posts atop existing concrete patio...anchor? #1
rbstern
Platinum Member
GA
LS MT225E, Yanmar 2210
I'm going to build a lean-to off the back of an existing house. The house has a concrete patio which exceeds the footprint dimensions of the lean-to, so the posts will be atop the concrete.
The question: Do these posts need to be anchored?
   / Setting posts atop existing concrete patio...anchor? #2
Yes. Otherwise if they get bumped they will move.
   / Setting posts atop existing concrete patio...anchor? #3
I would definitely secure the base of the post to the concrete. I like to use a steel spacer to separate the wood from the concrete - it's even code in some places. The spacer may then be anchored to the concrete with"Ramset" or something similar. I drill a hole to set the anchor then add a bolt. I prefer this system to driving in a stud leaving a threaded end sticking up.
   / Setting posts atop existing concrete patio...anchor? #4
   / Setting posts atop existing concrete patio...anchor? #5
The Simpson Strong Tie looks stronger and might be anchored using Tapcons - and washers if needed.
Okay. Anchored it is. Thanks for the feedback!
   / Setting posts atop existing concrete patio...anchor? #7
Good. I would not want to under estimate the power of wind gusts during a short thunderstorm. Might make the roof or shed sail.
   / Setting posts atop existing concrete patio...anchor? #8
just finished building new house.
i have 5 posts sitting on concrete slabs. the product described in the first link is what we used.
   / Setting posts atop existing concrete patio...anchor? #9
Don't forget the wind uplift forces which is a big reason to have the posts well tied to the concrete.
In deciding what fastener to use, consider the diameter. A Tapcon screw will be strong to start with but add a bit of corrosion and soon the cross section of the screw is significantly reduced. Corrode 1 mm around the screw and its strength is greatly reduced. Corrode 1 mm around a 1/2" diameter anchor and you have decades of strong performance left.
Fewer large diameter fasteners provide long term performance.
Dave M7040
   / Setting posts atop existing concrete patio...anchor? #10
I have a feeling that due to uplift that they are engineered to be used with 1/2 anchor bolts , you can jury rig lots of things to make them work, but it probably won't have the true strength that it was tested and engineered for.
2014 Ford F-250 4x4 Ext. Cab 8ft. Flatbed Truck (A55852)
2014 Ford F-250...
Honda Pioneer SXS700 4X4 Utility Cart (A53424)
Honda Pioneer...
72" ROCK BUCKET (A52706)
72" ROCK BUCKET...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
BUNDLE OF 4" - 6" X 12' BUILDING PURLIN (A54757)
BUNDLE OF 4" - 6"...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
