Dragonslayer
I have had my new to me BX2230 for about a month now. The tractor runs great but i was noticing that when cutting through medium to heavy mulch the belly mower would take on a harsh unbalanced sound. It sounded fine when cutting low grass with light mulch. So, today I pulled the belly mower off to check it out. The first thing I noticed was that the center blade was loose. In fact, the blade would turn free without engaging the belt and pulleys. The blade bolt was so loose I could unscrew it by hand and remove the blade.
The exposed end of the spindle shaft had splines with the last quarter inch being hexagon shaped. The blade had a round hole that was not splined. Should the blade hole be splined to match the splines on the shaft? Between the bolt and the blade there were three washers the top two had round holes and the bottom washer had an hexagon shaped hole that matched the end of the shaft. The round hole on the blade and the two top washers with round holes spinning on the splined shaft just didn't seem right.
Also, The PTO shaft gear box on top of the center spindle has a reservoir that was dry. Should this box be full of gear oil?
Would the combination of the loose blade and dry gear box be causing the harsh unbalanced sound I described?
