Service manuals for Branson Tractors
   / Service manuals for Branson Tractors #1
Asteral
Caddo Mills, Tx
LS TRACTORS
So i've had some people ask me for them so i wanted to make a list that is easy to access for everyone - Get your service Manuals Guys!!!!:laughing:
00 series Chassis, 00 series service manual - CHASSIS.pdf - Google Drive
00 series engine, 00 series service manual - ENGINE.pdf - Google Drive
old 10-20 series, 10-20 Series service manual.pdf - Google Drive
Current 15 series, 15 series service manual.pdf - Google Drive
Current 20 series, 20series.pdf - Google Drive
25 series Manual, https://drive.google.com/open?id=1MELKNIW4HCDV3fh5rV9J1gT9Q_csARhO
7845 Service Manual, https://drive.google.com/open?id=1hSgNkAgpDuM2LmbbeHX6CL5zRMkQ_c_n
3T series Engine , https://drive.google.com/open?id=1tHVvHfSobIZPAfiR6qgwJmRwBRGU4EzS
I hope this helps everyone who needs it.
   / Service manuals for Branson Tractors #2
Thanks for posting this. Wish they could make it a sticky at the top of the forum.
no problem i figured since i had them might as well share.
   / Service manuals for Branson Tractors #4
Can I impose upon you Asteral to seek intel on Branson parts from your contact in Branson? I can't believe that Branson would set up production to make their own filters but other members have said that the hydraulic filters, for example, are Branson specific (something to do with bypass valves). Here in Oz their is only one (yes 1) Branson vendor and, as a result, filters cost 50% to 100% more than in the States...I have found Donaldson (and other brands) air filters that suit the Branson but the oil\fuel\hydro\HST filters are all Branson labelled (in Korean) and no one has found their part numbers in any of the cross check cataloges. If your contact has generic part numbers it would really help us poor cousins Down Under.
Cheers,
Greg
I can ask him next time i speak to him i do know that for the older 20 series there is a wix crossover and i believe these are still the numbers for that,
air inner - 46489
air outer - 46490
engine - 51334
fuel - 33263
as for the main line hydraulic filter the only cross over number i could find here at my work was this one for a luber-finer filter - part# LFH4922 and this crosses over to this part # for donaldson P569383
   / Service manuals for Branson Tractors #6
Thanks Asteral, appreciated. The 6225h lists these Branson part numbers (air filter I have sorted...common type across multiple brands of tractor):
EA00001160B ELEMENT, LUBE OIL FILTER
TA00043153A FILTER, HST OIL
TA00025525B FILTER HYD OIL (20R/20C SERIES)
EA00005318A FUEL FILTER
   / Service manuals for Branson Tractors #7
This is Awesome! I definitely agree that it needs to be pinned to the top of the Forum here. I'm a month out from buying my Branson and not sure if I'm going with the 47 or 55 HP one. Going to check prices next week and start narrowing down the attachments.
   / Service manuals for Branson Tractors #8
Not to hijack, but the 5220r (55 hp, shuttle shift) is a awesome tractor! Mowing 6 ft grass with a 78” flail mower, the tractor lost about 50 rpms. The power and grunt are awesome. It needs to have the rear tires loaded, and I would suggest AG tires over the R4 industrial options. I have R4 and wish I had the grip of the AG options.
Get a canopy to keep you out of the sun. I am pleased.
   / Service manuals for Branson Tractors #9
Nice! Thanks for all the manuals Asteral!
This thread should definitely be fixed on top. Anyone know a moderator?
I think I can add some more stuff to this, like parts manuals and operators.
   / Service manuals for Branson Tractors #10
You might try running the rears at a lower pressure. On my 3725 about 16 psi is low enough to get the bars on the ground all the way across the tire. They came from the dealer (and after adding Rimguard) at more like 25. It's not a huge difference but its noticeable.
2014 Gillig Transport Bus (A50323)
2014 Gillig...
2016 HINO 268 26FT BOX TRUCK (A51222)
2016 HINO 268 26FT...
2013 RAM 5500 (INOPERABLE) (A50854)
2013 RAM 5500...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2008 DODGE RAM 3500 FLATBED TRK (INOPERABLE) (A50854)
2008 DODGE RAM...
