Serial number?
/ Serial number? #1
muddwhumper
Knoxville, Tennessee
Massey-Ferguson
Where can I find the serial number for this tractor? I don't know how old it is. I looked on the steering column and its not there. Where else can I look?
/ Serial number? #3
The serial numbers on the MF135 is on a metal tag about 2 x 3 inches It will either be on the dash on the left side. The early ones had it under the hood on the battery tray on the right side by the air cleaner. Prior to 1967 the serial number started with 641 1967 and after they start with 9A Hope this helps
/ Serial number?
Here is a pic of the dash. I think it (the tag) has been removed.
/ Serial number? #5
Your 135 has a vertical air cleaner. That indicates it is an early production unit. It was assembled in 1964 ,65, or 66.
INSPECTION (A65579)
INSPECTION (A65579)
2019 FORD F-150 XLT CREW CAB TRUCK (A63276)
2019 FORD F-150...
2018 Deere 650K LGP (A64126)
2018 Deere 650K...
2013 Atlas Copco XAS 400 JD7 Portable Air Compressor 125 PSI - Trailer Mounted - Tier 4 (A63689)
2013 Atlas Copco...
2009 Infiniti G37 Coupe (A64557)
2009 Infiniti G37...
Case skid steer wheels and tires (A63689)
Case skid steer...
