septic tank question
   / septic tank question #1
M E Cook
Bronze Member
SE TN
ls tractor
I know alot of you guys nave alot of knowledge so here goes I have a septic system by my shop my problem is i can;t tie straight into the inlet port i need to puy a 90 in at tank and run line towards the side of tnk will a90 at tank be ok
   / septic tank question #2
I would say its OK. My line runs out from the house about 12' then turns 90 deg. then goes 5' and into the tank. Once in the tank it has another 90 and down spout of 2'. I'm no expert nor did I install mine but its been that way for the past 30 years. Just be sure the entire line slopes to the tank.
   / septic tank question #3
OK, I had to read that about 6 times to parse it out, but I gather you need to make a turn for some reason. Solids don't like 90 degree turns even it water doesn't mind. It would be better to use two 45 degree elbows with a short straight piece between them if you have the room for that.
Another option would be a wider radius 'sweep' elbow.
yes i would use a long sweep 90 have to turn direction at tank right away will put clean out about 4 feet from 90 to have access
   / septic tank question #5
No, previous post was right. Two 45s with a short section between, clean outs every 50 feet. Reason being, most snakes only reach 50 feet and most snakes hate 90s. Make sure there is a tee at the tank outlet too, makes it harder for solids to float into the drain field.
ok 2 45s how short of a pipe between them? the total length the drain line will be about 5 feet before entering building
   / septic tank question #7
Can be as short as you want, 5-6”. We usually do it according to trench layout and use 1 foot on up.
   / septic tank question #8
I agree with others. A long sweep elbo or 2-45 deg elbows with a 6" to 12" between pipe. Hydro turd dymanics ! lol
   / septic tank question #10
Have you considered 45s?:rolleyes:
New Idea 6254 Round Baler (A50775)
New Idea 6254...
UNUSED (2) 3500# DROP AXLE W/ BRAKES (A54756)
UNUSED (2) 3500#...
2018 JCB 507-42 7,000lbs Rough Terrain Telehandler (A53421)
2018 JCB 507-42...
Utility Trailer (A52377)
Utility Trailer...
2025 JMR 72in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 72in Dual...
UNUSED FUTURE FT-S13 ELECTRIC MASSAGE CHAIR (A54757)
UNUSED FUTURE...
