Septic Tank Lid
/ Septic Tank Lid #21
I would try slowly turning the top, feel for any "click" or unusual bump and you may find the key-way. I think that arrow definitely marks a keyed point. Usually a "twist" off arrow points in the direction of turn like you've seen before.
Also as mentioned, I would locate the manufacturer and make a call if possible.
This thing probably is like a pill bottle to assure the lid stays on, (cupped lid) as you have found out!!!
/ Septic Tank Lid #23
it sort of looks like this norwesco look at the pdf there are 4 lugs
All the snyder and ace tanks are different on the top
the norwesco bruiser are different too
the pdf shows the lugs at 45 deg off center line of the plumbing
http://www.tank-depot.com/Drawings%2fTN6464ST.pdf
/ Septic Tank Lid #25
How many rural living forum members does it take to unscrew a tank lid?
:laughing::laughing: I'm waiting with bated breath to see how he makes out!
I really feel for people when they have septic problems.
JB.
/ Septic Tank Lid
Hey Thanks JB but I dont have a problem I have not had spetic tank pumped since i move out here so i thought it was time Turd sucker comes sat morning i was just getting it ready and wanted to peak in side to see what i could see lol. Any how i didnt have time last night to look at it so tonight i plan to spend some more time checking the lid for ways to come off if not like someone said im sure the turd sucker will know. I will try to keep ya updated on how this turns out for me .
/ Septic Tank Lid #28
:D
:laughing: :D :laughing: From what it looks like so far 3 pages worth and we still havn't removed it :laughing:
Hey, somebody's idea was correct. :laughing: We just do not know which idea. :D:D:D:D
This is exciting stuff. :laughing:
Later,
Dan
/ Septic Tank Lid #29
I think you all are full of c...:laughing:
/ Septic Tank Lid #30
Interesting, here the lid has to be above ground. Mine has a concrete lid at ground level that just lifts off exposing the inner lid on top of the tank that also just lifts off. Whatever you do, don't fall in.
Mine is concrete and is burried about 6 inches under the surface. I have a flower bed over top of it and hit the top digging it up(flower bed) and when planting.
/ Septic Tank Lid #32
I can give you a hint of what you'll see.....??? :D
:laughing::laughing::laughing: Yeah! In the big picture, it may be a blessing that he can't get that lid off. YUCK!:thumbdown:
However, the two big slots look like indentions for a big spanner wrench to turn the lid. With the "Open" arrow, I have to believe a turn to align a release slot is what it needs.
/ Septic Tank Lid
Hey all the lid is off had 4 notches that lined up and off it came. And man was I surpriced at what i saw???? There hidden in the cornor was Jimmy Hoffa
/ Septic Tank Lid #34
:thumbsup: Was there alot of sludge? did it really need cleaning?
JB
/ Septic Tank Lid
Pumper man comes sat morning but looks to me like it needs pumped lot of sludge on top perty heavy flim poked stick to bottom didn't feel much at bottom will see what pumper man says either way i'm haveing him pump it out start fresh. Has been very interesting to this point .
/ Septic Tank Lid #37
Close the lid fast!! You don't want any politicians gett'en out before the pumper arrives!!!:D
I bet getting the lid off is a "load" off your mind, good deal.:)
/ Septic Tank Lid #39
JEEZ, I have been following this thread since it began and I am really disappointed in the end result.
Sorry, but I think the whole thing STINKS.
/ Septic Tank Lid #40
The scum on top is grease, which doesn't break down. Cooking grease, mechanic grease from the laundry, oils from your skin, whatever. Avoid putting oils and grease down a septic whenever possible.
Solids at the bottom will be food that doesn't break down. Some plants have a high silica content, and will not digest. Colored toilet paper is another lump. Always use white. A garbage disposal puts a bunch of crud in the tank, better to compost the garbage. Bones in particular won't break down. Bones and grease being so durable, that's why Jimmy Hoffa was still recognizable.
2007 International 4300 Bucket Truck 55' (A62613)
2007 International...
2 BALE HAY SPEAR (A63291)
2 BALE HAY SPEAR...
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
Kubota L4802 DT LA766 Backhoe (A63688)
Kubota L4802 DT...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 INTERNATIONAL...
Peterbilt 377 Semi-Truck (A63689)
Peterbilt 377...
