Septic / Drain Field Issues
   / Septic / Drain Field Issues #11
So you are saying the drawing is “maybe” 100mm off?
And if that drawing (with unknown distance to tank bottom) were to be followed it would “quickly” clog because of that approximate 100mm difference?
Realizing now that the tank bottom is not shown - the drawing is probably correct if there is sufficient depth in the tank to allow for sludge build up. The depth from the bottom of the outlet elbow to the bottom of the tank basically determines how often you need to pump the tank.
CATERPILLAR 140M2 MOTOR GRADER (A52706)
CATERPILLAR 140M2...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
Giyi Excavator Root Rake (A53316)
Giyi Excavator...
Giyi Mini Log Splitter (A53316)
Giyi Mini Log...
PREVIEW DATES AND TIMES (A54865)
PREVIEW DATES AND...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51691)
2015 Toro Multi...
