Sensitrak Shifting
   / Sensitrak Shifting #1
AndyG
SW Indiana
My '04 TC40D has Supersteer and the Sensitrak clutch. When I move the shift lever into 4wd lock all works well. When I move the lever back to auto the clutch does not release. I have to get off of the tractor and grab the shift lever on the side of the clutch housing and move it back to the auto position. Seems like there is a burr on the shifting mechanism or it needs a heavier spring. Anyone else have this trouble? How do I fix it?
   / Sensitrak Shifting #2
Andy if the cable starts to get a bit sticky you'll experience the same situation. I might suggest removing the cable from the hand lever mechanism and find out which is binding first, then you can better deal with it.
I will check the cable.
Thanks
The cable is working fine. In fact there is slack where it connects to the gearbox. The shaft going into the side of the Sensitrak box is sticking in the "ON" position.
UNUSED GOLD MOUNTAIN M122009 12'X20' STEEL CARPORT (A51248)
UNUSED GOLD...
2020 Bell TC-11A Crawler Carrier (A52384)
2020 Bell TC-11A...
John Deere 772-A Grader (A52384)
John Deere 772-A...
TORO Z MASTER 4000 PRO HDX ZERO TURN MOWER (A51247)
TORO Z MASTER 4000...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
JOHN DEERE 3020 TRACTOR (A51247)
JOHN DEERE 3020...
