Sensitrak Shifting
   / Sensitrak Shifting #1
AndyG
SW Indiana
My '04 TC40D has Supersteer and the Sensitrak clutch. When I move the shift lever into 4wd lock all works well. When I move the lever back to auto the clutch does not release. I have to get off of the tractor and grab the shift lever on the side of the clutch housing and move it back to the auto position. Seems like there is a burr on the shifting mechanism or it needs a heavier spring. Anyone else have this trouble? How do I fix it?
   / Sensitrak Shifting #2
Andy if the cable starts to get a bit sticky you'll experience the same situation. I might suggest removing the cable from the hand lever mechanism and find out which is binding first, then you can better deal with it.
I will check the cable.
The cable is working fine. In fact there is slack where it connects to the gearbox. The shaft going into the side of the Sensitrak box is sticking in the "ON" position.
JOHN DEERE 7210R TRACTOR (A51247)
JOHN DEERE 7210R...
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
2002 LULL 644B-42 TELESCOPIC FORKLIFT (A51246)
2002 LULL 644B-42...
JOHN DEERE 408R (A53084)
JOHN DEERE 408R...
Wolverine 72" Hydraulic Skid Steer Tiller, New  (A52384)
Wolverine 72"...
