Semi with LOOOOOOOONG tank on tralier
   / Semi with LOOOOOOOONG tank on tralier #1
aczlan
Good Morning
Northern Fingerlakes region of NY, USA
Kubota L3830GST, B7500HST, BX2660. Formerly: Case 480F LL, David Brown 880UE
Anyone seen anything like this?
Looks sort of like a large propane storage tank... We saw it a few weeks back at a rest area on I-81 South in PA.
There were also a pair of trailers with rings that looked like parts to a vertical storage tank.
Sorry for the fuzzy pictures, the camera was using long exposures to compensate for the low light
Aaron Z
   / Semi with LOOOOOOOONG tank on tralier #2
Did you ask what it was and how long? I live near a port that the wind towers come into. they are pertty long but I think your load has got them beat!:)
I think this was a 3 truck convoy, but the drivers were all gone. The trailers with rings on them were missing trucks, so I suspect that they had all left in those trucks (and/or in the escort vehicle(s). If there had been anyone around I would have asked.
Aaron Z
   / Semi with LOOOOOOOONG tank on tralier #4
Aaron Z
That fact sounds incredible. You'd think that something bound to attract attention like that would sure have somebody there to keep an eye on it.
As to what it is, it seems the length of the tank would indicate some sort of heat exchanger. It just doesn't make sense to build a huge storage tank somewhere and haul it like that. It has to be something that couldn't be built on-site. I have no idea what the 11-ton tanks might be. If I had to guess, I'd say some type of boiler vessels.
   / Semi with LOOOOOOOONG tank on tralier #5
Most likely a pressure vessel. For co2 or nh3 something contained at high pressure. They can't be manufactured on site do to the welding process. Some of these things can hold over 400 psi, they need good welds.
If there was someone there, they werent in sight and didnt come out to see what I was doing. But then, I was staying at least 3 feet away and not touching anything.
I think it has to be a pressure storage tank of some kind. It had 3 6-8" ports on the top and one access plate, but the rest were smaller.
On the bottom, the only port I saw was plugged (looked like a drain).
Aaron Z
The company hauling it was based out of Quebec (based on the plates on the tractor/trailers and the logos on the tractor).
Aaron Z
   / Semi with LOOOOOOOONG tank on tralier #8
Aaron,
Not sure where you are in upstate but there is a similar looking tank parked at Longways Truck Stop north of Watertown. It's been there at least a week. I wish I had looked it over better and taken a pic. If it's still there next time to Watertown I will.
   / Semi with LOOOOOOOONG tank on tralier #9
This load is bigger :laughing::laughing::laughing:
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A54811)
2015 Toro Multi...
2015 International DuraStar 4300 Johnston VT651 Street Sweeper Truck (A55788)
2015 International...
2012 Ford F-150 Crew Cab Pickup Truck (A53422)
2012 Ford F-150...
(APPROX 32) 6' X 12' HEAVY CHAIN LINK SITE PANELS (A54757)
(APPROX 32) 6' X...
UNUSED LANDHONOR HPF-11-3000G HYD PALLET FORKS (A54757)
UNUSED LANDHONOR...
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2017 CATERPILLAR...
