semi-mount?
/ semi-mount? #1
Dmax
ARKANSAS
KUBOTA M6800SDC
semi-mount?
looking at buying a new rotary cutter. I am looking at a 8' or 9' cutter and need to be able to load and unload easily on my trailer. So I was wondering if lift type is my only option or can the semi mount be lifted completely off the ground while loading on to trailer?
/ semi-mount? #2
Re: semi-mount?
A semi-mount cutter does not use the top link of the three point hitch, therefore it can not be lifted off the ground. The rear wheels on the semi-mount are controled by either a manual adjustment ratchet or a hydrulic cylinder.
/ semi-mount? #3
Re: semi-mount?
Base on your profile, IMHO I do not think that your tractor will handle a 8 or 9 foot lift type mower. Your tractor only has net pto hp of 37.5 and most of these mowers require a greater hp in the range of 45-60 hp at the pto.
/ semi-mount?
Re: semi-mount?
Guess I needed to update my profile and I have now. I have a M6800SDC now.
NEW 2025 Trailer by Premiere Single Axle 12' Tilt  (A62679)
NEW 2025 Trailer...
3142 (A63117)
3142 (A63117)
2020 Patriot 12' Enclosed Trailer (A66285)
2020 Patriot 12'...
1994 Geo Tracker, 5spd, Soft Top (A62679)
1994 Geo Tracker...
(4) 12-16.5 Tires (A65640)
(4) 12-16.5 Tires...
JOHN DEERE 5403 TRACTOR (A65643)
JOHN DEERE 5403...
