semi-mount?
   / semi-mount? #1
Dmax
Bronze Member
ARKANSAS
KUBOTA M6800SDC
semi-mount?
looking at buying a new rotary cutter. I am looking at a 8' or 9' cutter and need to be able to load and unload easily on my trailer. So I was wondering if lift type is my only option or can the semi mount be lifted completely off the ground while loading on to trailer?
   / semi-mount? #2
Re: semi-mount?
A semi-mount cutter does not use the top link of the three point hitch, therefore it can not be lifted off the ground. The rear wheels on the semi-mount are controled by either a manual adjustment ratchet or a hydrulic cylinder.
   / semi-mount? #3
Re: semi-mount?
Base on your profile, IMHO I do not think that your tractor will handle a 8 or 9 foot lift type mower. Your tractor only has net pto hp of 37.5 and most of these mowers require a greater hp in the range of 45-60 hp at the pto.
   / semi-mount?
Re: semi-mount?
Guess I needed to update my profile and I have now. I have a M6800SDC now.
2000 Safari C-Series 425 40ft Panther Motorhome (A49461)
2000 Safari...
2008 MAGNUM PRODUCTS LIGHT TOWER (A50854)
2008 MAGNUM...
196046 (A50459)
196046 (A50459)
Ford 641 Workmaster (A50514)
Ford 641...
2016 CHEVROLET SILVERADO 2500 HD CREW CAB TRUCK (A51243)
2016 CHEVROLET...
2007 INTERNATIONAL MA025 DAY CAB (A51219)
2007 INTERNATIONAL...
