Self Leveling Kit
/ Self Leveling Kit #1
ToolcatWonka5610
Mount Morris, Michigan
My uncle told me a few days ago that back in the 90s Allied or some company made a Self Leveling Kit for your loader. The way it worked is as you Pull/Push the joystick, the mechanism would open the Bucket Dump and Curl value just enough to keep the load level. Is anyone familiar or heard of this? :confused:
/ Self Leveling Kit #2
Yes, there are a number of these out there. Several manufacturers put them on their front end loaders. Depending on the FEL geometry, they can be pretty simple mechanics or more complex electronics. With the PT "level indicator", it wouldn't be hard to rig something up.
That said, I can't say that I have really felt the need. For my own uses, other items rank higher-I'm still considering adding laser leveling to the PT.
All the best,
Peter
/ Self Leveling Kit #4
Oh, I don't know how about these;
  • Laying out terraces,
  • keeping the arena flat,
  • correcting slopes in driveways,
  • keeping berms in shape to gently divert rainfall,
  • water tank pads,
  • constant slope drain lines,
  • putting in fire break roads...
All the best,
Peter
A laser level for??????? Inquiring minds want to know....
/ Self Leveling Kit #5
  • water tank pads,
All the best,
Peter
Oh... those tasks. :D
/ Self Leveling Kit #7
Bear in mind that different gizmos have different ideas of what constitutes level. e.g. parallel to the tractor, parallel to the ground, perpendicular to gravity... The first two are cheap and I have seen them on a number of tractors.
On flat ground, in the barnyard or building site, they all approximate to the same thing, but not on slopes or crowns...
All the best,
Peter
I believe it came in a kit that you put on the loader. Any loader that would work.
/ Self Leveling Kit #8
Hi, I see your point on the angle of tractor in relation to level,, thats why I'm working on a level indicator, which will show bucket true level on all grades.. picures to follow..
2018 RoGator 1100C (A63688)
2018 RoGator 1100C...
2016 JCB 3CX 4x4 Loader Backhoe (A64194)
2016 JCB 3CX 4x4...
JOHN DEERE 7420 TRACTOR (A63291)
JOHN DEERE 7420...
Lot 602 (A62613)
Lot 602 (A62613)
Kubota V1505-T Turbo Diesel Industrial Engine  Pump Takeout (A63689)
Kubota V1505-T...
2009 PALFINGER 11 FT SERVICE BODY (A62613)
2009 PALFINGER 11...
