Ballast Self filling of tires with washer fluid practical?
   / Self filling of tires with washer fluid practical? #11
That's a great idea. Too bad there's no such thing as used wiper fluid!
   / Self filling of tires with washer fluid practical? #12
Interesting. I'll look into that. Thanks!
Hi GSS and all,
A local establishment [Pharmor] is going out of business here...felt kind of funny with me and the wife both pushing shopping carts nearly overflowing with gallon jugs of windshield wiper fluid to the check out. I bought a totol of fifty gallons at 71 cents per gallon. Figure what is left over will go into the car and van...
Also got one of those little drill pumps for under $6. Now I am wondering if I need one of those filling valve devices. Seems to me I could just rig up something where a thin tube goes in the tire valve stem, with some space around it to let out air as the fluid goes in. The rear wheels would naturally be up off the ground, I think I could use the backhoe stabilizers to hold the rear wheels off the ground while filling the tires.
Maybe I will do a trial run and fill the tires on the back of my little MTD garden tractor tomorrow! Yes, that is a great idea, I have been wanting to put more weight on the back of that thing anyway. Great test to see whether I need to buy one of those special valves. Hope I can find some tubing that will be small enough!
By the way, fifty gallon jugs is a lot. I have a van so it was no problem, but in a regular car...hope the trunk is a big one or you may have to make two trips. No big deal though.
Then again, all you tractor guys probably drive pickups...so there should not be any problem at all!
Will let you know how the test fill goes tomorrow if I do it...
Bill
   / Self filling of tires with washer fluid practical? #14
<font color=blue>where a thin tube goes in the tire valve stem, with some space around it to let out air</font color=blue>
I'll be very surprised if you can find a tube thin enough, and if you do it'll be so small that it would take forever to get any liquid through it; personal opinion. My recommendation would be a tube just big enough to fit over and onto the valve stem, pump in some liquid, remove the tube to let out air, and repeat until fluid comes out when you let out the air.
   / Self filling of tires with washer fluid practical? #15
[censored], that is a really good idea! Just got off the phone with the wife, so hopefully she'll hit the motherload at the local PharMor... Thanks!
I already bought one of those fluid valves from Gempler's, so since you are in the area, you are welcome to borrow it. No need to spend the cash and time waiting for it when you already have the fluid and are ready to go. I'll be treking around a little bit tomorrow (Sat), so let me know and I'd be happy to meet you somewhere.
- Gerald
   / Self filling of tires with washer fluid practical? #16
Wow, I didn't realize dam (with an n) would get censored. Sorry if I offended anyone...
Bill, you rule! I just went to PharMor at lunch and they had a boat load of it left. Picked up 100 gallons, so I can do all 4 wheels. Thanks a lot for the great tip. If you want to use my valve thingy, please do not hesitate to call me. I'll email you my phone number.
I am in your debt...
- Gerald
   / Self filling of tires with washer fluid practical? #17
No offense here, but it wasn't needed to tell us what you wanted us to know. I like the fact that our posts don't have unnecessary words.
   / Self filling of tires with washer fluid practical? #18
No, it wasn't needed. But I like to convey emotion in what I write so it's not the same ole boring spew... Some people use smileys; I use interjections.
I disagree. At least a quarter of the posts in these threads are shootin' the breeze, matter-of-fact comments and "unnecessary words".
That's all I am going to say about that.
   / Self filling of tires with washer fluid practical? #19
I think that "unnecessary" might have been the wrong word to use in your case. Politically correct might be more appropriate. :)
Don
   / Self filling of tires with washer fluid practical? #20
Below is the info from a post I made a few months ago. I have a BX1800 so I didn't need as much fluid but the process is the same:
Thought I'd share the procedure I used to fill my rear tires with 10 Gal each of windshield washer fluid. I drilled a small hole in the cap and inserted plastic tubing, then used hot glue gun to seal. Plastic tubing runs to a metal tubing inserted into tire valve. Plastic jug is then inverted and a hole cut out the bottom and obviously must be higher than the tire. Make hole big enough to pour the fluid into this jug as it becomes empty. Metal tubing needs to be 1/8" outside diameter, plastic tubing just large enough to slip over the metal tube. Jack tractor up just enough to take weight off wheels. Takes about 25 minutes per gallon. Including the tool to remove the valve core the cost is about $3 plus washer fluid @ 84 cents/gallon.
2017 FREIGHTLINER M2 106 (A53843)
2017 FREIGHTLINER...
UNUSED FUTURE TRP12 MINI 3PT RIPPER (A52706)
UNUSED FUTURE...
2017 Ford F-150 Crew Cab Pickup Truck with Liftgate (A55852)
2017 Ford F-150...
Year: 2018 Make: Chevrolet Model: Tahoe Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: (A55853)
Year: 2018 Make...
2012 Chevrolet Silverado 3500HD Enclosed Service Truck (A53422)
2012 Chevrolet...
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A55302)
2023 Kubota...
