self contained / portable hyds.
/ self contained / portable hyds. #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
was looking at the local paper and see HF has the small gas engines on sale for like 99$ again. always makes me think about getting a small gas engine and coupling with a spare hyd pump like from a tractor cranksahft setup.. that and an oil drum or similar as a sump.. some hosing and a couple DA circuits via inexpensive logsplitter valves and some QD outlets and you could have a 'porta-power' for about 400$ ( depending on what parts you already have or don't have ) high volume too.. not one of these lil electric over hyd ones.
any comments?
soundguy
/ self contained / portable hyds. #2
Good idea.
I was thinking of the same thing as I have several engine and a couple of spare pumps.
Using a 2.5 GPM pump with a potential pressure of 3000 psi, will take about 5 HP.
I only need a valve, filter and small reservoir.
yep.. I have a pump setting on the shelf.. and the 6.5hp engines are 99$ with super coupon.
have various metal drums from 1-15g in size. got hoses.. even got a few spare valves.
all would need is a framework, and rigging it all up, appropriate valve and qd's.
perhaps mount it in a tube cage. i think i have an old honda genny or trash pump that died and I still have the tube cage.. that or add 3pt pins too it too.. or mount on a carryall. ideas are limitless. would make a standalone power source for a log splitter for sure.. cheap too.
soundguy
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2005 JLG G6-42A Telehandler (A62613)
2005 JLG G6-42A...
2019 Caterpillar 349FL Hydraulic Excavator (A61572)
2019 Caterpillar...
CASE TV370 SKID STEER (A62129)
CASE TV370 SKID...
1975 Bomag MPH1 Soil Reclaimer Mixer (A61572)
1975 Bomag MPH1...
2016 Kia Forte Sedan (A61574)
2016 Kia Forte...
Here are some similar links:
