Seeking power steering diagnostic advice on an 861
   / Seeking power steering diagnostic advice on an 861 #1
nickfank
Ohio
1957 Ford Powermaster 861, NH TC30, Kawasaki Mule, Derby ZTR
Hi All-
I just acquired a 57-ish 861 with bad power steering. I'm getting ready to dig into the problem. Before starting, I figured I should check in here to find out if there are any "usual suspects" known to experienced owners that I should look for right away.
So far, all I've done is to replace the filter on the pump & note that there is fluid coming out of the pump. (Don't know what the pressure is- just that it's flowing.)
I don't know if there's more than one type of PS system, but what I have involves a hydraulic cylinder going to the front wheel on each side. They appear to be double-acting. I'd guess that turning the steering wheel bumps a valve off-center that stays open until the action of the cylinders re-centers the valve.
Neither cylinder is moving, so my problem is at a level that would affect both. (I'm getting no assist at all.)
There must be a return path to the pump that is normally open. Could that be stuck in the open position? Any pressure relief valves that might be prone to sticking?
If y'all don't have any likely trouble spots to suggest, I guess I'll just look for that centering valve, and work outward from there.
Any thoughts?
Regards,
-Nick
   / Seeking power steering diagnostic advice on an 861 #2
pump has a relief, and the steering column has a valve block.
2018 HONDA RECON 250 4-WHEELER (A51247)
2018 HONDA RECON...
2022 Club Car Tempo Cart (A51694)
2022 Club Car...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
2022 Cub Cadet Ultima ZT1 54 in Lawn Mower (A53117)
2022 Cub Cadet...
2014 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2014 DRAGON...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
