Seeding a new pasture
   / Seeding a new pasture #11
For pasture seeding, audsp98 would want a mixture of seed varieties.
As someone mentioned, a soil test would be very helpful and can save money in the long run. At a bare minimum be sure the soil PH is suitable. Without the right PH level, much of any added fertilizer will be wasted, producing a poor crop.
   / Seeding a new pasture #13
As joeu235 states... use your County Extension. They are already paid for and typically have a pretty good understanding of how things grow and work in your area.
And as Oldoak states... a mixture is by far preferable for a pasture. A mix of 'cool and warm season' grasses will allow growth throughout the year. And the last thing you want is some funky virus/fungus to hit your 1-grass field, and go through it like fire. Clover mixed with grasses can be beneficial in that it provides Nitrogen fixation for your grass.
But one thing... make sure you get the 'CLEANEST SEED' you can get. Especially if you are planting a mix broad leaf (clover) and grass. Because you really limit your ability to fight weeds in a mix.
   / Seeding a new pasture #14
... a mixture is by far preferable for a pasture. .
One negative for a mixture is it makes it harder to apply herbicide. Its really hard to spray summer weeds and keep your clover, at least where we live. A monoculture means you can find one that doesn't affect the specific plant you are growing.
   / Seeding a new pasture #15
Certainly. But even a mixture of grasses would be preferable to a single grass species which grows well only under certain conditions. In KY, Orchard and Bluegrass are commonly sown together for a combination of cool season and warm season growth. If you aren't worried about lactating mares, then adding fescue to these 2 above would give you a great pasture which can still be sprayed for broadleaf weeds. (I don't know about Alabama though... it will likely be a different mix of appropriate grasses for that climate/latitude).
   / Seeding a new pasture #16
I live in Pass Christian, MS. Over the past eight years i have established several pastures with Argentine bahia. Goats, cows, and horses do well on it. It is drought tolerant and has crowded out most other grasses and nearly all weeds.
   / Seeding a new pasture #17
What is growing on the land now? I have some land that was clear cut a couple of years ago and just mowing it has resulted in grass growing. Granted it has abut 4 different types but it would feed a goat with no problem. The deer seem to like it fine.
I am eventually going to spray it with Pasture Pro from TSC and maybe follow up with one of their pasture mixes. The Pasture Pro says to treat twice a year to keep the broad leaf weeds under control.
   / Seeding a new pasture #18
I'd agree with the suggestion of contacting the local extension -- it may also be helpful to discuss what you plan on doing with the cows as (from my understanding) there are some different considerations for dairy cows vs. cattle being raised for beef.
I'd also expect that for the long term a blend of will be preferable as goats and cows tend to be more complimentary diets rather than having a whole lot of overlap. One (rather enthusiastic) article on the topic:
Using Goats for Vegetation Management
Personally, unless there are hillsides or other terrain features that would drive a lot of erosion I think I'd wait another month or two letting natural vegetation grow and then seed/over-seed when the conditions are more favorable for germination. Granted if the weather has been as wet there as it has been here in Northern Alabama pasture mixes might not have too much of a problem. From everything I've read right now isn't a recommended time to be planting many types of pasture vegetation due to the temperatures: http://www.aces.edu/pubs/docs/A/ANR-0149/ANR-0149.pdf
However, your local extension will likely have much better guidance for your area on when/what to plant for your situation and future plans.
INDUSTRIAS AMERICA F12T HYD TILT LAND LEVELER (A51406)
INDUSTRIAS AMERICA...
2001 Subaru Outback AWD SUV (A51694)
2001 Subaru...
(INOP) 2024 ATLAS CORPO PACF44 DEWATERING PUMP (A52705)
(INOP) 2024 ATLAS...
30pc 3ft. x 8ft. Red Polycarbonate panels (A53424)
30pc 3ft. x 8ft...
UNUSED GRASSROOTS IMPLEMENT 5' BOX BLADE (A54756)
UNUSED GRASSROOTS...
2021 CATERPILLAR 302.7 CR EXCAVATOR (A52705)
2021 CATERPILLAR...
