Planters Seeders vs. Planters
/ Seeders vs. Planters #1
sagaponack
Sagaponack, NY
JD 755 1993
I have my heart set on a JD Flexiplanter 71 to seed sunflowers and feed corn. I am told that this cannot help seed wildflowers which is more like seeding grass.
Someone recommended a billion seeder but they are a fortune. Any alternatives? Would a drop spreader and a power rake work as well?
What the heck is a power rake?
Thanks for the advice
/ Seeders vs. Planters #2
sagaponack
How large an area are you planning on planting w/sunflower and how much with wildflower? Will this be a onetime planting or do you plan on planting every year?
I only plant about 2-3 acres to sunflower each year, wildflowers I have planted (5 acres) are mixed annual/perrenials (sp?), and plant about an acres new each year. With the wildflowers, I use an over-the-shoulder broadcast spreader, then use a 6' water filled roller to roll them in. Sunflowers still go in the old fashioned way....by hand....but my 7 & 11 y.o. still enjoy helping with this part of the chore. However, I am only doing it to feed the the critters and my own enjoyment, nothing commercial.
Paul
I am doing an acre of wildflowers. A little bit under that for sunflowers. 1 acre for feed corn too.
Did you get a good turn out with the broadcast method?
No problem with birds eating them?
That is an amazing amount of sunflowers to do by hand. How many people did it?
...I will be doing this each year...
/ Seeders vs. Planters #4
Yes, got pretty good results with the brpadcast method on the wildflowers. Didn't lose as much to birds/turkeys. As the wildflower seed is pretty small, the roller pretty much got them into the ground.
As for the sunflowers, I spread the planting out over a two week period. AND most importantly, let my 2 daughters help out (11 and 8). When planting the sunflowers, I don't hoe rows or furow them. just lay a string to keep rows straight, then hand the girls 2 walking sticks which are painted on the end. they drop a seed on the ground and push it into dirt until the paint can no longer be seen. Of course, I get to help out too.
Does take as long as you'd think. When this years patch comes up, I'll snap some with the digital cam and post them on here.
I was amazed just how fast deer can clear cut a sunflower patch though. But since the sunflowers were for the critters to feed on, didn't mind too much. As a side note, out of curiosity, I also took about a half acre plot and used 'sunflower seed' packaged as bird seed to see what would happen. I broadcast it, then ran the tiller over it (set to about 2 inches)..Believe it or not, most of the came up/bloomed, but very small plants.
Good luck!
Paul
/ Seeders vs. Planters #5
I use a broadcast seeder behind my 4-wheeler then use a 4x6 metal grate to drag over it and cover it. I do 10 fields about 1/2 acre each and it takes me a full day to do all of them. I just bought a bx2200 so i am looking forward to using it as well as the 4 wheeler.
New/Unused 16 Gallon Landhonor Vacuum Cleaner (A65583)
New/Unused 16...
2014 Ford F-250 Utility/Service Truck, VIN # 1FDBF2A67EEA87424 (A65563)
2014 Ford F-250...
40' One-Trip Shipping Container (A66285)
40' One-Trip...
2007 Komatsu WA200-5 (A64047)
2007 Komatsu...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
2018 Roadtec RP190E Highway Class Wheel Asphalt Paver (A64553)
2018 Roadtec...
