Seed Bed Creation
   / Seed Bed Creation #11
I'm planning to sell organic vegetables from this plot, won't Roundup affect the plants? Also, What is a Harley Rake? (Mentioned in comments )
if you're planning to sell certified organic, doubt you'd qualify using Roundup. wouldn't take much research to find out. guess it all depends on the grower's honesty. great project, worth doing the homework.
Realizing that i counter the American mainstream's heavy use of glycophosphates, i wouldn't dream of using the product for food consumption at any stage & know many would argue otherwise. regards, good luck.
will you have the means to irrigate the patch? seems to me drought will be a challenge these days
   / Seed Bed Creation #12
You cannot claim organic status for any vegetables grown with herbicides, which certainly includes the herbicide Roundup/Glycophosphate. If you go "certified organic" whoever controls that term in your location will be visiting you periodically, unannounced, to check your produce and soil for residual herbicide/pesticides. Generally speaking, it takes four (4) years of cultivation to purge chemicals from pasture soil before produce can be labeled organic. Sophistidcated soil tests, which the farmer pays for, are the progress checkers.
I was involved in certified organic grape growing in California for ten years. Growing organic produce of any sort is a much more complicated and expensive process than growing the same produce with chemicals. I would NOT attempt growing produce organically until having several profitable years growing vegetables with chemicals.
I will also add, I hope unnecessarily, that marketing vegetables grown with chemicals as organic is FRAUD which could subject the fraudster to severe penalties, including incarceration. In California the Department of Agriculture monitored the Farmer's markets, in my day. Some consumers are allergic to herbicides and pesticides and buy organic produce to protect their health. Potential for civil suits against fraudster if consumers sickened. Attorneys happy to take on such law suits on a contingency basis in California.
HARLEY RAKE: https://www.youtube.com/watch?v=GzxTa2odFFI
For preparing/cultivating your commercial garden you need to buy or borrow a 12" or 14" moldboard plow and buy a PTO powered roto-tiller and buy row cultivators way before you need a Harley Rake.
ROW CULTIVATOR:
   / Seed Bed Creation #13
If you add your LOCATION to your T-B-N PROFILE you will receive advice much better tailored to your region.
   / Seed Bed Creation #14
You could use vinegar. Just do a soil test after you've plowed, disced or rototilled it.
   / Seed Bed Creation #15
Roundup/Glyphosate will only effect what you're spraying it own. If it's a concern for your organics wait a couple weeks and a good rain before planting.
   / Seed Bed Creation #16
I do not understand the need to use Round Up for a simple garden plot. Plow it this fall. Cover it with organic materials, leaves, straw, saw dust after taking the soil samples. Plow it in the spring at 90 degrees and then disk it. Add fertilizer at each row of plants.
There is no magic way to prep your garden it will be work. The second year will be better. I would also get one of the propane sidewalk deicers to kill the weeds between the rows.
If you are going to do raised beds with a plastic covering the prep will still be the same.
Start looking for organic compost pile materials.
   / Seed Bed Creation
I'd like to create a 24'X100' seed bed from a FLAT piece of horse pasture.
Mow the grass as short as possible. Scalp.
Spray the stubble with Roundup or generic Glycophosphate.
(Herbicide is most effective when the grass is growing vigorously.)
(In Florida pasture grasses are variations on Bahia. Bahia roots go down 6" to 9".
Unless herbicide is used, mechanically disturbed grass roots will rebound before garden seeds can get a good start.)
Wait ten days for herbicide to have effect, then dissipate.
When the soil is Moist but not wet, use a PTO powered roto-tiller to mix and level the soil.
Two passes with the PTO powered roto-tiller may be necessary.
Do not over till. Two passes should be sufficient.
Great info Jeff, thanks. I'm considering covering the bed with weed cloth as opposed to spraying the area with herbicide, your thoughts?
   / Seed Bed Creation #18
Weed mulch cloth is fine but inorganic, costly and labor intensive.
Consider at thick blanket of straw as mulch, or other organic material without seed heads, which will decay into the soil, improving it. Wood chips from a tree service is another possibility, although slow to decay. Some cities compost fall leaves, which residents can haul away at no cost in late Spring.
2017 Freightliner MT55 Step Van (A55788)
2017 Freightliner...
Giyi 44" Mini Grapple (A53316)
Giyi 44" Mini...
(30) 24-A Macro Bins (A53316)
(30) 24-A Macro...
Case 480E LL (A53314)
2017 Polaris 500 Ranger Diesel Utility Cart (A55787)
2017 Polaris 500...
2007 John Deere 5603 (A53314)
2007 John Deere...
