JC, the seat switch used to be a simple single pole switch that made continuity in the circuit. The newer switches have 3 wires going to to them and I believe do more than just provide continuity in one circuit. I'm just not sure, but it has been discussed before that it is more difficult to bypass. Without a specific circuit diagram, I'm not going to give what may be wrong info to somebody. I do know that the switches are now inside the seat and are very hard to get to. Just removing the connector and jumpering pins in a plug without knowing what it should be is a sure invitation for a blown fuse.
It would be a simple thing to monitor the switch functions by penetrating the insulation on the wires and using a voltmeter, but it's hard to do that underneath a seat you are sitting on so you can apply 75 lb of force to make/break the contacts.
