Seat safety switch
   / Seat safety switch #1
gmorgan6
I have a TC30 and untill recently I could start and let run the tractor while not seated, as long as the brake was set and the the range put in neutral.
Is there an adjustment for the seat safety switch that allows the tractor to run when not in the seat and all other safety things are set? Thanks for any info. JM
   / Seat safety switch #2
:welcome:
You may have a PTO switch/lever engaged that might affect the start process.
I assume if the PTO switch were engaged the tractor would not start while I was in the seat. Is this not correct?
   / Seat safety switch #4
My guess is that your parking brake switch is not functioning properly. Do you have a parking brake light illuminated on the dash? It could be an adjustment of the switch or even bad contacts.
I think I need to clarify my problem, I can start the tractor with no problems
while in the seat.
When I want to get off the tractor I lock the brake put it in neutral, both gear and range. Make sure the PTO is not engaged,then when I get off the tractor It dies, it did not do this before. So I assume it has to do with the seat switch.
Also I can push down on the seat while off the tractor it will start as soon as I remove the pressure it dies.
   / Seat safety switch #6
Do you have a mid PTO ?
   / Seat safety switch #7
Your seat switch is working perfectly. Don't be distracted by that. The problem is that your parking brake being ON is NOT being sensed. That's why the tractor dies. The tractor thinks you just got out of the seat with the brake off, so it shuts down. Check the parking brake switch. You'll be happy you did.;)
Jinman,
Thanks, I understand now I will check that tomorrow, will post the outcome.
JM
Jinman, You were right on with checking the brake switch, one wire was broken, I spliced soldered and taped it works great.
Thanks for setting me straight.
JM
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A51248)
UNUSED RAYTREE...
2014 Nissan Pathfinder SUV (A51694)
2014 Nissan...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
Unused 2025 SDLANCH SDLL30 Mini Track Loader Skid Steer (A51691)
Unused 2025...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
