Seat safety switch TC40DA
   / Seat safety switch TC40DA #1
jpbear
West Virgina
NH TC40DA
I just got my TC40DA and am trying to bypass the safety switch. Made a jumper with male spades and plugged it into (2) female slots diagonally from each other. There are (4) female slots on my plug. I tried other combinations but that was the one that would let me get off the seat and the tractor still runs. It works other then beeping when I take the e-brake off and start to move. Does anyone have a way to do it so it doesn't beep?
Thanks,
Joe
   / Seat safety switch TC40DA #3
No personal experience with the DA models, but I didn't think they were much different in operation from my 2001 TC40D:
1. Placing the Range Selector in Neutral.
2. Turn off the PTO.
3. Set the parking Brake.
If it doesn't work that way there may be a problem with the switch.
There is a difference in the safety switch in the D and DA models, and michigander II gave a good link with pictures.
Thanks for the replies. Chris, the switch works fine when plugged in. I just don't like it. The link that michiganderII is good except that my plug is (4) slots in a square not (4) across. I only jumped corner to corner. I will make another jumper to do the other corners and see if that helps. It works now with the jumper I have in. Just beeps at me when I go to start moving.
thanks,
Joe
   / Seat safety switch TC40DA #5
thanks,
Joe
Hmmm... something still seems weird, can you post some pictures of the switch. Do you have a Fluke or anything else that you can test your switch with... Looks like quite a few people are having issues with these dang switches...
M.
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A53472)
2023 New Holland...
2019 GEHL R105 WHEELED SKID STEER (A51242)
2019 GEHL R105...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
2019 Freightliner 122SD, Cummins X15 (A52384)
2019 Freightliner...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
