Seat hinge repair---who da thought????
   / Seat hinge repair---who da thought???? #1
al3
Central Wi
JD 4110, X500
Never even considered the seat mounting points would fatigue and break. Guess I should stop before dessert at dinner? Most likely too many side hill adventures in the woods.
At any rate, the underside of the seats sheet metal skin is spot welded to 1/8 inch flat bar stock which has 90 degree bends at either end. Permits a through rod to attach the seat to the sub frame. One side of the 1/8in bar broke clean off; in the process some of the surrounding 18ga metal fatigued and broke off too.
Some hammer and dolly work to flatten things out, a file to shorten stretched metal, and a few less- than- impressive welds and spots put things back together again.
Only reason I posted this is to provide a heads up---repair would have been a lot easier if I caught it quicker. Never thought to look. Suppose it doesn稚 matter if you have a plastic seat base.
   / Seat hinge repair---who da thought???? #2
What tractor is under this seat ? Age and/or hours?
4110 (compact). 680+hrs. Think they used the same seat design on a few other compacts and lawn/garden tractors in early to mid 2000's.
   / Seat hinge repair---who da thought???? #4
Nice welds!
ECHO CS590 CHAIN SAW (A51248)
ECHO CS590 CHAIN...
2013 International WorkStar 7400 4x4 Altec DMA71 Insulated Digger Derrick Truck (A51692)
2013 International...
UNUSED SWICT 66" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 66"...
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
2016 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A53426)
2016 FREIGHTLINER...
UNUSED WOLVERINE BC-13-72W-72" HYD BRUSH CUTTER (A51248)
UNUSED WOLVERINE...
