seat cover repair
   / seat cover repair #1
deminin
Central Missouri
Kubota B2910
I've got a minor problem on my B2910....the vinyl seat covering is coming loose from the cushion. I would like to find some way to glue that down before the seat cover begins to fall apart. I am thinking about injecting some contact glue into the area with a hypodermic needle....the glue should seal the small holes, and hopefully the contact glue won't damage the foam rubber underneath. Any ideas....has anyone had/fixed this kind of minor issue.
   / seat cover repair #2
I had the same thing happen with my seat. I was on eBay where I found seat covers. I got one and I am getting another to protect my other seat . They were sold by tractorboyparts . These were John Deere ones. Maybe they can get other ones. Hope that helps you.
   / seat cover repair #3
I had a small triangular cut in my brand new seat.
1 inch square of duct tape works great.
   / seat cover repair #4
headliner glue maybee.
3m makes some good spray adhesives that won't attack foam..
then cover with some vinyl repair tape to seal it perhaps?
soundguy
   / seat cover repair
Fixed it. Lowe's sells a Loctite glue for Vinyl/fabric repair, and I filled an old computer printer ink refill hypodermic needle with the glue, and injected the glue at 3 points. Then I pushed the vinyl back down onto the foam, and held it for a few minutes. The glue held, and sealed up the 3 tiny holes, so now the seat is back to like new, and you have to look real hard to see where the needle marks are.
   / seat cover repair #6
cool thanks for the report. will have to look at that. I have a seat with a piece of vinyl lifting..
PALLET OF OIL COOLERS (A53843)
PALLET OF OIL...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A53473)
2017 KINZE...
2014 RAM 2500 (INOPERABLE) (A53843)
2014 RAM 2500...
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
2015 TROXEL 130BBL KILL TRAILER (A53843)
2015 TROXEL 130BBL...
