Sears Rider no battery charge
   / Sears Rider no battery charge #1
smokeless
kubota
Hello,
I have sears riding mower bout 12 years old. Been having some starting issues so i measured voltage while running.
Meter remained at 12V while running. Does anyone have some fault isolation procedures they would share? I assume there is a V regulator i could check.
Any help much appreciated, thanks
   / Sears Rider no battery charge #2
Welcome to TBN. We could do much better with engine and chassis numbers, or if it is simpler post a pic of the engine/ regulator if it has one.
   / Sears Rider no battery charge #3
Voltage regs are cheap . not sure what model you have but on the bigger engines its on the side and a simple swap ,.
I checked yesterday but could not locate model. Will check again and if all fails will post a pic, thanks for posting
Not familiar with these mowers at all, but maybe a pic will help. Sure appreciate you folks taking the time to help, more later
I have a pic from the left side facing the mower. Just by the starter are some wires thay appear to go under the top cowling. The wires go back towards battery compartment but could not identify a reg box.
Does the following help?
Stamped on a cover on the front of the engine.
Model 407777
Type 0607 E2
Code 050822YG
If something comes to mind i would be plenty appreciative.
   / Sears Rider no battery charge #7
Tks, but where is it located on the mower? Under cowling maybe??
   / Sears Rider no battery charge #9
Should be on the side of engine the wires would run under cowling
   / Sears Rider no battery charge #10
your profile does not say where you are but I have 4 sears riders behind my shop for parts come on and pick you a part
2007 CATERPILLAR D5GXL CRAWLER DOZER (A51406)
2007 CATERPILLAR...
HARDEE D-3-816 LOT NUMBER 155 (A53084)
HARDEE D-3-816 LOT...
2012 JACK COUNTY 130 BBL VACUUM TRAILER (A52472)
2012 JACK COUNTY...
City of Buckhannon - 2014 Ford Fusion SE (A52384)
City of Buckhannon...
2010 THOMPSON TRASH PUMP (A51406)
2010 THOMPSON...
2009 Freightliner B2 School Bus (A51692)
2009 Freightliner...
