Sears LT1000 Ride on was working fine, running then dead...
   / Sears LT1000 Ride on was working fine, running then dead... #1
Joebklyn
I was using my Sears LT 1000 (917.272082- Kohler CV490 Type 27509) ride on. Just refueled it and drove a bit to hook up a wagon. As it was sitting there running fine it just died. Turn the key and nada. No click nothing. Battery is new and good. Just had to make a major repair 2 weeks ago. Needed a new flywheel key in the process I changed the ignition module, new fuel lines & filter. Can anybody can point me in the right direction? I'm a noob to this stuff and can't afford a real mechanic. Thanks Joe
   / Sears LT1000 Ride on was working fine, running then dead... #2
Well, if it died and then no crank- I would suspect that the fuse has popped.The next question is why.
Thank You! Now I've got to find the fuse and report what I've found.
Solved: Besides a blown fuse it was the solenoid that broke. I also found a loose ground wire. Thank You TomPlum for pointing me in the right direction.
   / Sears LT1000 Ride on was working fine, running then dead... #5
Thank you for reporting back!
   / Sears LT1000 Ride on was working fine, running then dead... #6
I had a Sears go down like that because of the seat sensor safety thing go bad. Jumped the safety switch and boom worked
STORAGE FEES (A51219)
2014 Ford Escape SE SUV (A48082)
2014 Ford Escape...
2003 Chevrolet Silverado 1500 HD Crew Cab Pickup Truck (A48081)
2003 Chevrolet...
2019 Cadillac XT5 SUV (A48082)
2019 Cadillac XT5...
2012 Ford F-350 Mechanics Service Truck (A48081)
2012 Ford F-350...
2016 Chevrolet Impala Limited Sedan (A48082)
2016 Chevrolet...
