Sears LT1000 Ride on was working fine, running then dead...
   / Sears LT1000 Ride on was working fine, running then dead... #1
Joebklyn
I was using my Sears LT 1000 (917.272082- Kohler CV490 Type 27509) ride on. Just refueled it and drove a bit to hook up a wagon. As it was sitting there running fine it just died. Turn the key and nada. No click nothing. Battery is new and good. Just had to make a major repair 2 weeks ago. Needed a new flywheel key in the process I changed the ignition module, new fuel lines & filter. Can anybody can point me in the right direction? I'm a noob to this stuff and can't afford a real mechanic. Thanks Joe
   / Sears LT1000 Ride on was working fine, running then dead... #2
Well, if it died and then no crank- I would suspect that the fuse has popped.The next question is why.
Thank You! Now I've got to find the fuse and report what I've found.
Solved: Besides a blown fuse it was the solenoid that broke. I also found a loose ground wire. Thank You TomPlum for pointing me in the right direction.
   / Sears LT1000 Ride on was working fine, running then dead... #5
Thank you for reporting back!
   / Sears LT1000 Ride on was working fine, running then dead... #6
I had a Sears go down like that because of the seat sensor safety thing go bad. Jumped the safety switch and boom worked
2011 MAGNUM PRODUCTS LIGHT TOWER/WATER TANK TRAILER (A50854)
2011 MAGNUM...
2014 Whisper Watt Generator (A49461)
2014 Whisper Watt...
2018 Toyota RAV4 SUV (A50324)
2018 Toyota RAV4...
WEATHERFORD MP-10 TRIPLEX MUD PUMP POWERED BY A CATERPILLAR 3412 ENGINE (A50854)
WEATHERFORD MP-10...
2014 Kinze 1100T Dual Auger Grain Cart (A50657)
2014 Kinze 1100T...
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
