Sears GT5000 3-pt hitch retrofit
   / Sears GT5000 3-pt hitch retrofit #1
Alcon
Sears GT5000 garden tractor
I have an electric 3-pt hitch (NOT a sleeve hitch) that I removed from a Sears Suburban SS18 and would like to mount it to my 2004 Sears GT5000, as I am not impressed with the Sears sleeve hitch set-up. However, I found that when the SS18 hitch is placed on the GT5000 rear frame, the gas tank of the GT5000 blocks the upward movement of the 3-pt hitch. Is there an adapter bracket that I can use to make this retrofit possible?
   / Sears GT5000 3-pt hitch retrofit #2
Can you post some pictures? If so I might be able to help. I also have about an '05 GT5000 and would be interested in that setup for mine.
   / Sears GT5000 3-pt hitch retrofit #3
If you can't make that 3 point set up work, you might want to take a look at the electric sleeve hitch at "Johnny Products". I have that and it works great --- I've found a lot more small sleeve hitch implements than Cat 0 3 point implements.
2011 FORD F-450 (A52472)
2011 FORD F-450...
2017 Ford Explorer AWD SUV (A53424)
2017 Ford Explorer...
2010 Club Car Electric Cart (A53424)
2010 Club Car...
2015 GREAT DANE ETL-1114-31053 REEFER TRAILER (A54607)
2015 GREAT DANE...
2017 Hino 268 20ft Flatbed Truck (A52377)
2017 Hino 268 20ft...
