Need to check compression on down cylinder. Could be rings, valves or scouring on the cylinder walls. How many hours on motor? If near the 1000 hr mark, could be DOA. You've been through carb and pump, say you have spark? If no spark on just that one side, you need to trace the grounding lead to that side coil. As they say, spark, fuel and compression, it'll run!
