Searching for LS Tractor model that the 5740 Montana was derived from? Cross posted
   / Searching for LS Tractor model that the 5740 Montana was derived from? Cross posted #12
I recently purchased a 5740C at auction as a salvage tractor. In the diagnostic process I have come to the conclusion that there is a broken shaft in the engine sump area. When started there is a rattle & heavy scraping (not an engine knock), oil pressure is in excess of 60 lbs, my gauge limit. The engine assembly looks like it will lift off the cast iron pan as it appears that the crankshaft is geared to some shafts in the pan/sump area, most certainly the source of my evil engine noise. The necessary engine removal process looks to be fairly straight forward but I was wondering if there might be a 'gotcha' or 2 in there that I need to be aware of? Any words of wisdom or experience would be appreciated. The second part of my search here regards a tractor service manual. I have researched this forum & the web and have come to the conclusion that the Montana manual is sketchy at best. A forum member is emailing one to me but I am also wondering if anyone has been successful at identifying an LS Tractor model that the Montana 5740 is derived from? Neo 53 or 60? Wishful thinking maybe? I am wondering if LS might be an additional source of information or a manual? Thanks in advance for any info you may have.
We are located in Astoria, OR and started with Montana and now carry the LS tractors. Parts are readily available for the most part and we have the original Montana service manuals, although they aren't the best service manuals I've seen. Happy to help you if we can. -Jeremy
   / Searching for LS Tractor model that the 5740 Montana was derived from? Cross posted #13
Have you tried to contact LS directly. I did this for my Farmtrac and the gave me the info with no hassle. Farmtrac DTC300=LS C3030
Jeremy
2015 Hyundai Sonata Hybrid Sedan (A55758)
2015 Hyundai...
Toy Trucks and Excavators (A53316)
Toy Trucks and...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
UNUSED 20 in. Gasoline Chain Saw (A53117)
UNUSED 20 in...
Killbros 350 Gravity Wagon (A50775)
Killbros 350...
Mini Excavator Rake (A53316)
Mini Excavator...
