Sealing the roof seams
   / Sealing the roof seams #1
valley
Platinum Member
mountain valley near Tahoe
Michigan 55A, Foton 254
Greetings, Just repaired and painted the horse trailer, wish I had a picture to show what it was like. I would like to seal the roof seams.
What have you used that has worked?
Thankyou
Richard
This is what it looks like Now.
   / Sealing the roof seams #3
I sealed the roof of my 2-horse gooseneck trailer last year. I sealed first, then painted. I used something called Dap 3.0 Advanced Blacktop & Roof Sealant. Home Depot sells it in my area (WV). The 3.0 stands for a 3 hour cure before being able to paint. It comes in standard caulking-sized tubes (about 2" diameter X 8 1/2" long). It cures to a hard but flexible, somewhat tacky consistency. It comes in black and white color.
After more than a year out in the weather, there are no leaks. So far so good.
horsepuller, Thanks, I just saw your post. RE: the DAP 3.0. That sounds good, you did yours last year, are you still pleased? Thankyou
Richard
   / Sealing the roof seams #5
The sealer seems to be holding up well. I have no leaks. I also used it to seal the seams between the floor mats in the trailer and along the mat-wall joints. This is a tougher job; some of the mat-to-mat joints have come unsealed.
Overall I am satisfied.
   / Sealing the roof seams #6
I have an 83 motorhome that I sealed the roof using a cream colored thick sealant bought from an RV dealer. I recall the price was a bit high for a gallon but I sealed the roof about 10 years ago and it is still in place with no cracks or leaks, I also sealed along the tops of all windows, still pliable. This product had to be applied using a brush or putty knife and it will slowly flow to level. Whatever you do, dont use any of the old silver or aluminum colored roof cement, it is pure junk that will crack when the trailer flexes, leak, then require complete removal. Good luck.
Thanks guys for taking the time to post what you've done. Sorry for taking so long to get back, haven't checket this thread for a while.
Richard
UNUSED WOLVERINE DB-15-84W 84" HYD ANGLE BLADE (A51248)
UNUSED WOLVERINE...
2012 KOMATSU WA470-6 WHEEL LOADER (A51246)
2012 KOMATSU...
2001 Ford Ranger Pickup Truck (A51694)
2001 Ford Ranger...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
1987 Ravens 45 ft. T/A Float Trailer (A53117)
1987 Ravens 45 ft...
2018 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2018 John Deere...
