Sealing tach on John Deere 1020
   / Sealing tach on John Deere 1020 #1
Workin fool
Pa
John Deere 1020
I have a John Deere 1020 serial #79000. Gas engine serial #123000. Does the engine and clutch need split to put seal and bushing on tach input cable. Also does the end of tach have a seal to keep oil from going up cable. From what I see there is a bushing I believe T31437. Can it be put on from the outside of housing. Parts man gave me seal T21827 I don’t see it on any diagrams. It is a small white washer 1/2” diameter with 1/8 hole in center. Does it go over cable end of tach it is about the same size of the cable drive.
   / Sealing tach on John Deere 1020 #2
There is washer P/N R26919 that goes between the clutch housing and the flywheel housing. T31437 goes on the tach cable, then cable installs into clutch housing.
T21827 is used when no tach, it installs into clutch housing from the outside, then a plug goes in, rather than a tach cable.
Parts man might know this is a labor saver to install T21837 into the clutch housing then the tach cable (don't forget the bushing T31437), if you forgot R26919 when you did a clutch split???
I would install T21837 if I forgot R26919.
Thank you for your in-depth precise answer
   / Sealing tach on John Deere 1020 #4
I forgot to add the the plastic bushing centers the inner drive cable in the outer cable
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
1989 Freightliner Cabover FLA086 (A52748)
1989 Freightliner...
Manac Walking Floor Trailer (A50322)
Manac Walking...
EZ-GO MPT 1000 Electric Utility Cart (A51694)
EZ-GO MPT 1000...
2017 FORD F150 REG CAB LONG BED 4X4 (A52577)
2017 FORD F150 REG...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A50324)
2004 Fleetwood...
