Sealing T1-11 joints
   / Sealing T1-11 joints #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
The back of the barn is facing north and when storm hits - like yesterday and today - it leaks little bit in joints. What could I use to seal it to make it watertight? Caulking maybe? Anybody has an experience with it? I dont think normal barn paint would fix it, correct?
Thanks for any suggestions.
   / Sealing T1-11 joints #2
I am a little surprised that you are getting leaking through T-1 11 if is on the vertical joints. The T-111 I have used is tongue and grooved as well as being nailed to a framing member at the joints. If it is leaking at a horizontal joint where two sheets meet, we have always run a flashing like drip edge along the seam.
I would think that chalk would be your best bet at this point. Unfortunately chalk will not stand the test of time well if not painted.
MarkV
   / Sealing T1-11 joints #3
Prokop,
Depending on what joint, end/but or side? The but uses a "Z" shaped pc of flashing. You see about 1/2". Side joints..caulk
2017 JEEP CHEROKEE (A53843)
2017 JEEP CHEROKEE...
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
2015 Ford Taurus SE Sedan (A54815)
2015 Ford Taurus...
2006 Pierce Dash Fire Truck (A51692)
2006 Pierce Dash...
